Humming Noise
Old Aug 9, 2006 | 03:45 AM
Caracicatriz's Avatar
What was that?
Humming Noise
This is my first post in the 5th gen forum so don't flame me. My mom's car is making a humming noise when driving on the highway. Automatically I figured it was the wheel bearing. When we took it to the mechanic he said that all of the wheel bearings were good and said the noise is coming from the middle of the car. I tried to pinpoint where the sound was coming from and conclude that it was coming from the middle of the car. If it's not the wheel bearings, what could it be?
Old Aug 9, 2006 | 04:15 AM
MAXI BLUE 03's Avatar
i am having a similar problem, but i am also getting a shake in the front end that caused all 4 of my tires to go out of round (michelin pilot sport a/s with 7k on them) i brought my 03 max to 7 different people and they have no idea.
Old Aug 9, 2006 | 09:16 AM
What was that?
bump......
Old Aug 9, 2006 | 11:01 AM
bsetiawan's Avatar
My sister's old autotragic also has humming noise starting at 90 mph. No idea what it is either.
Old Aug 9, 2006 | 11:11 AM
E55AMG2's Avatar
Wat
You probably have bent wheels. It's a lot more common than people think.
Old Aug 9, 2006 | 04:00 PM
i just brought to a rim shop and they were the one's that said, not bent wheels, just 4 out of round tires?
Old Aug 10, 2006 | 07:26 AM
E55AMG2's Avatar
Wat
With michelins, its highly unlikely that you got 4 out of round tires. Its more likely that you have wheels w/ a little runout from a slight bend. Have them check both just in case.
Old Aug 10, 2006 | 06:34 PM
on monday i am going to switch wheels with my buddy and see if his car shakes and if mine rides smooth he has the same tires and wheels and no vibration.
Old Aug 10, 2006 | 06:38 PM
irish44j's Avatar
retired moderator
just fyi....bad bearings are VERY common on maximas....not saying that's your problem, but it's not unusual.
then again, maybe there's a reason mine go bad all the time (see sig pic)...
Old Aug 10, 2006 | 06:42 PM
siren001's Avatar
I too have that sound not tires, thought it was so bought new ones still noise only on one side, wont make the noise on jack stands, grabbed rotor and tried to wiggle it and it wouldnt bearring inthe middle looked good.
Old Aug 10, 2006 | 07:45 PM
ctrent86's Avatar
How often did your "sister" go faster than 90?
Old Aug 11, 2006 | 03:37 AM
i recently had all 4 bearings replaced
replaced front struts
replaced front rotors & pads
7 mechanics said front end is tight
Old Aug 11, 2006 | 03:40 AM
MaxBoost925's Avatar
Drug Money
tight as in?
Old Aug 11, 2006 | 06:05 AM
nothing bent or loose
i just had my tires spun on the road force balancer and the shop said that all four tires are wearing perfectly and not out of round, however my car still shakes/vibrates
Old Aug 12, 2006 | 01:36 PM
Glob's Avatar
I have the same issue right now: humming noise from the rear from 20mph.
I have Maxima SE 2000, 115K miles, never changed bearings or struts.
Checked rear brakes, all looks good. I have Michelin tires also(60K miles on them, still look Ok, but I am going to change them next week, may be noise is going to go away).
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
