Cheap gas sound
Cheap gas sound
I got a 03 maxima and i only put premium gas in it, but for some reason im getting that sound like if im putting that cheap stuff in it.
I had the car for about 5 months and i never used cheap stuff and once in a while i put gas treatments and fuel injections cleaners, but its once in a while.
That sound is really getting me on my nerve.
What could it be.
What could it be.
Originally Posted by trigger005
that sound ur hearin is a sound
the sound is most likely a result of a sound
so the sound will most likely sound like a sound caused by a sound
anyway, is the sound you're hearing like a ping or a knock? If you're putting 91 or 93 octane gas in your car, that's not the problem...when do you hear the sound? under load?
if u want help, please describe this "sound" as it my be a symptom of something else
Originally Posted by LA02MAX
drugs?
the "sound" could be caused by
1. bad knock sensor
2. bad engine mounts
3. loose heat shield for all the hell that sh!tty description tells
u must b on drugs if u didnt get my sarcasm
1. bad knock sensor
1. bad knock sensor
I agree, though...it's sort of hard to diagnose anything if the description is that vague, which is why I asked him all those questions...
The sound is only happening when i hit the gas. I had a 97 max before i got my 03 max and i heard the same sound when i put anying under 91 in my 97 max.
Im pretty sure u guys no the difference when u put 93 or 87 octane. I makes the car sound like s**t.
I have never use anything under 93 on my 03 max so i dont understand why its making that sound.
lock thread
this is goin nowhere
Funny sound when pressing gas
I have a 03 max, i had the car for 5 months and never used anything less than 93. When i press the gas pedal i hear a funny sound, its has a bubblie, bubblie sound.
This sound is driving me crazy. Its only when i accelarate at low speeds,
yeah, but i really didnt get any help. I need some assistance with this problem, before going to a stealership
The sound is like a light rattle, or best described as a "ping". Is it more likely to happen when it is warm outside? Does it happen btw 1800-2500 rpm? Welcome to the world of VQ35 pinging. It is normal, and annoying. Some have tried the oil catch can (scroll through the threads) with good results.
Originally Posted by Yayomax
ok, when you hear this mystery sound, does it happen more so if the engine is warmed up or cold. Under heavy or light acceleration, or a combo of the two.
it doesnt matter if the cae is worm or cold. And it not a pining or rattling noise. Its sounds like it air or some type of liquid. Dont know what the previous owner put in the car. it dosent even matter inf i fill the car with gas or put half a tank. Same even if theres little gas, same old sound.
DTC 1320 and 0300
I have a 2000 Maxima 5 spd. The car is misfiring between 1k and 2k rpms and i am getting the knocking and or pinging also I look under the car and the front cat right under the engine is fire red inside. The scan tool is giving me DTC codes 1320 and 0300. I have replaced all coils and spark plugs, EGR valve, and tested all the cam and crank sensors, and the MAF is also good, and i still have the same problem. Can anyone help me or has anyone seen a problem like this before???????
streetz look around in the all motor forum: http://forums.maxima.org/forumdisplay.php?f=79
pretty much the only thing you can do is write 15 useful posts around the forum (don't make them useless or else you'll get banned.) so that you can make your own thread or look here: http://forums.maxima.org/showthread.php?t=487272
post the same question there and it'll get answered better, because not many people enjoy others hijacking their threads...
Andy29
Sep 29, 2015 05:32 AM
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
pears
Sep 18, 2015 05:25 AM
