HELP ASAP: Axle Boot Cover Thingy Ripped
Old Aug 13, 2006 | 08:29 AM
AceofSpds's Avatar
wat
Ok the boot thing on the axle near the spindel has ripped on the passenger side i need help w/ this asap what are some quick fixes so that it doesnt sling oil/grease everywhere and what is a permanent fix... You can probably tell by now how im panicing that i dont know jack **** about this and i cant find my haynes book help would be greatly appreciated.
Old Aug 13, 2006 | 08:47 AM
2002 Maxima SE's Avatar
Short term: You can get a kit like this:
http://www.thepartsbin.com/repsite/n...t~reparts.html
Long term: You need to replace the axle. Would recommend:
www.raxles.com
Old Aug 13, 2006 | 09:06 AM
AceofSpds's Avatar
wat
I mean really short term that can cover the tear or soemthing untill i can have enough time to take off the spindel etc... >.< such a pain why does something like this happen when school starts again this week!
Old Aug 13, 2006 | 09:26 AM
FriscoMaxima's Avatar
lol... axle boot cover THINGY...
Old Aug 13, 2006 | 10:03 AM
trigger005's Avatar
yeap well he is 17
Old Aug 13, 2006 | 10:46 AM
alpinestars™'s Avatar
THIS IS...
Would you really need to replace the entire axle though? Same thing happened to me, I was wondering this as well...
Old Aug 13, 2006 | 11:34 AM
irish44j's Avatar
retired moderator
yes. unless you have the expertise to take the whole thing apart, clean, and reassemble. It's a PITA, big time. Once the boot is torn, all it takes is a couple grains of sand to get in there and start ruining the CV joint.
Old Aug 13, 2006 | 12:57 PM
shurik's Avatar
Short Term!
www.raxles.com
I say go for the short term, it's cheaper and easier! I had the same exact problem on my car, on the same front side! I bought that kind of kit like the link shows (only for the Maxima), and it worked. Only the clamp they'll ship with it will not be good enough, it won't hold it properly. I tried different aftermarket clamps and they all sucked!!! At the end had to go to a dealership and buy the proper stock clamp for $8 that the axles come with. The clamp should be wide enought and strong enough to support the boot, that's why go for the OEM one, the boot of course could be the aftermarket one.
If it's the outer boot that is ripped, you don't have to take the whole thing apart like Irish says, you can take just the boot off with the axle on the car and work around it.
Old Aug 13, 2006 | 01:13 PM
xnyc's Avatar
if you kno how to change the boot, change the boot. wen you disassemble it, you gotta clean it anyway. just make sure it doesnt stay exposed for too long cuz if alot of particles get in it, your joint will get ruined after you change the boot. easiest way is to get a remanufactured axle and change it. other than that, go to a shop and haev it done professionally
Old Aug 13, 2006 | 01:30 PM
irish44j's Avatar
retired moderator
What I meant is that once the original boot is ripped, there is a good chance that debris has already gotten in there, so you might as well just put in a new axle.....I'm not a big fan of "temporary fixes..." I'd rather just do a long-term fix the first time and not have tomess with it any more.
Old Aug 13, 2006 | 01:39 PM
AceofSpds's Avatar
wat
Im pretty shure i know how 2 do it, I helped my friend replace his axles before.
When i get a new axle its gonna be a raxle, i dont care too much for remanufactured parts, especially when there isnt that much of a price difference.
jonreidhead
Jan 6, 2016 09:38 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
