what are some simple tune up tips
Old Aug 18, 2006 | 07:59 PM
amimaxima
hello everyone im looking to do a large tune up on my car. 60,000 miles
what are some common things that people clean, replace and fix?
Old Aug 18, 2006 | 08:04 PM
irish44j's Avatar
retired moderator
oil chage
coolant flush
MT change (if you're MT)
spark plugs
check coolant hoses
also check out the fluids and lubricants section here, it has alot of good info on tuneup stuff.
Old Aug 19, 2006 | 12:12 AM
limsandy's Avatar
Missing 2 most important things, but good start....
- Rotate tires
- Inflate tires to proper pressure
Old Aug 19, 2006 | 04:59 AM
KLOOGY's Avatar
L33t BMW Drivah
- Rotate tires
She is 100% correct !
Old Aug 19, 2006 | 07:57 AM
SoonerFan's Avatar
Cletus
its all in your owners manual...or here http://www.nissanusa.com/apps/techpublications
Old Aug 19, 2006 | 08:18 AM
joebangaa's Avatar
some people also like to change the fuel filter... i probably will once i hit 60k
Old Aug 19, 2006 | 11:13 AM
amimaxima
oil
oil filter
coolant flush
MT flush
power steering flush
brake flush
spark plugs
check coolant hoses
Rotate tires
fuel filter
pcv valve
belt replacement
tighten throttle cable
clean or replace air filter
clean coil packs
clean throttle body
replace drain plug and washer
seafoam
replace radiator cap
is there anything anyone else can think of?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
9aj9
Apr 5, 2020 12:11 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Socalstillen
Sep 26, 2015 12:01 PM
