6th gen rims/tires
Old Aug 23, 2006 | 12:49 PM
rowen93se's Avatar
6th gen rims/tires
I bought a set of 6th gen rims and tires. I noticed the tires are a larger diameter, does anyone have experience with this? The car is stock but i have a set of H&R springs I'd like to put in, I hope there isn't going to be a clearance issue.
Old Aug 23, 2006 | 12:52 PM
LA02MAX's Avatar
that's because they come with 245/45/18...you would need 235/45/18...they probably won't rub with H&Rs as that is a mild drop, but your spedometer will be off a bit.
Old Aug 23, 2006 | 05:23 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
you won't have major problems with that set up.. the car will rub in the back every once in a while... nothing big.... I have 245's in the back and it is fine.... I have maxspeeds installed....
Old Aug 23, 2006 | 05:55 PM
westler92
225/40R18's on the Max right now.........
I have seen a lot of Max's here in LV with 6 Gen rims.....and to me they are ooglay
Old Aug 23, 2006 | 06:03 PM
vsamoylov
245/40/18 and they dont rub with H&R. i had that set-up before.
Old Aug 23, 2006 | 06:23 PM
misiek's Avatar
dropped on tein's and no problems
Old Aug 23, 2006 | 07:19 PM
aw89maxSE's Avatar
that looks good
Old Aug 23, 2006 | 07:22 PM
misiek's Avatar
thanks
Old Aug 23, 2006 | 07:51 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Gotta say I like the look of the 6th gen rims as well.
Old Aug 24, 2006 | 12:05 PM
naxray's Avatar
I've have a set of these rims in my garage waiting for my current tires to need replacing, so I'm curious as well...Lontar1 and misiek - what aspect ratio are the 245's you're running? 40 or 45?
Thanks!
Old Aug 24, 2006 | 12:15 PM
04BlackMaxx's Avatar
Ill have a set of 6th gen rims available within the next 2 months, PM me if you are going to be interested. 1 has curb rash, the other 3 are good condition. Tires are GY eagle F1 DS-G3
Old Aug 24, 2006 | 01:05 PM
misiek's Avatar
Thanks!
245/40/18 10char....
Old Aug 24, 2006 | 05:13 PM
TitaniuMax03's Avatar
this pic was from last year..dropped on Progress Techs...no issues for me either..
Old Aug 24, 2006 | 05:42 PM
vsamoylov
so true. 245/40/18
imported_Nismo_max
Sep 21, 2015 07:24 PM
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
