alignment question
Old Aug 24, 2006 | 10:39 AM
d3van's Avatar
alignment question
Hi guys, I installed some Ksports about a month ago and drove around with my car absolutely slammed to the ground for about 3 weeks. During that time I noticed my alignment was out a bit, but not too bad. I recently found time to adjust the height to something more sane, but my alignment feels really outta wack now. The steering wheel has to be held about a quarter turn to the right to go straight.
I need to get an alignment right away, but do I need to do all 4 wheels or just the fronts?
PS, the Ksports are awesome.
Old Aug 24, 2006 | 10:40 AM
MAXRB8's Avatar
The sooner the better , and yes all 4 wheels.
Old Aug 24, 2006 | 12:23 PM
joebangaa's Avatar
^^ uh, our rears can't be adjusted
Old Aug 24, 2006 | 12:24 PM
LA02MAX's Avatar
just the fronts...
Old Aug 24, 2006 | 12:36 PM
boondoxmax's Avatar
Just fronts. Thrust alignment is what they called it when I got my alignment done. They align the fronts with the back, but no adjustments are made to the rear. $39.99 was all I paid for 2 wheel alignment
Old Aug 24, 2006 | 02:21 PM
TopSpeedNY's Avatar
I have a question to guys, when lowering the car to much about 2.2 inch's do i need progress camber kit or no cause my alignment been done 3 times in about a month.
Mike
Old Aug 24, 2006 | 02:48 PM
d3van's Avatar
Damn, I went and paid for a 4 wheel, and looking at the datasheet they didnt adjust the rears at all.... I should have posted the question sooner.
My camber on my front right is -2.9 though, and they recommended a camber kit(bolts) for about $70 installed. I will likely do some more adjustments in the next month or so before getting another alignment done, and maybe go to a different place to see if they can get my front right a little less negative.
Old Aug 24, 2006 | 05:11 PM
MAXRB8's Avatar
My bad, apologies, I should have been clearer, as others have mentioned the fronts are aligned to the rears only the fronts are actually adjusted.
Old Aug 24, 2006 | 06:19 PM
steven88's Avatar
Need A Light?
no need for the $70 bolts...your ksports already has a camber kit on top...to adjust camber...if that isn't enough, they can adjust camer through the lower shock bolts...
Old Aug 25, 2006 | 09:43 AM
d3van's Avatar
Thats what those adjustments on the top hats are for... Lol, I totally forgot about them. But what do I need to know to adjust camber using those(like, how do I do it/can I do it myself?). Also, how do I go about adjusting camber through the lower bolts?
After reading 1,000's of posts on the issue, I knew we didn't need camber kits for the ksports, but as I am a super-n00b with this stuff I didn't exactly know why.
Old Aug 25, 2006 | 10:56 AM
boondoxmax's Avatar
direct tire 39.99 for 2 wheel alignment. Stopped going to dealer after they charged me 79.99 and said all there alignments are same price
Old Aug 25, 2006 | 03:54 PM
Raf2kMax's Avatar
you can go to any shop even if your car is lowered with a kit? i used to hear that you have to go to a shop with a certain type of machine that aligns the fronts if you have lowered your car...
or maybe its if you have a kit on, itll scrape??
i dunno
Old Aug 25, 2006 | 04:01 PM
steven88's Avatar
Need A Light?
just tell the alignment guys "i have a camber kit, it's under the hood"...and they will take care of it...
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
