Motor Mounts
Old Aug 31, 2006 | 01:49 PM
A33 VQ30DEK's Avatar
Motor Mounts
Who makes them? and where can i buy them?
Old Aug 31, 2006 | 02:06 PM
DrKlop's Avatar
Driving is the next best thing
http://suspension.com/
I believe they cost $70. But you'll have to reuse the brackets...
You can get a full setup (with the brackets) from Cattman, but it'll cost you $260.
Old Aug 31, 2006 | 02:11 PM
MacGarnicle's Avatar
what do better mounts do anyway? reduce engine movement?
Old Aug 31, 2006 | 02:16 PM
DrKlop's Avatar
exactly! No more wheel hop (for the most part) and the car feels more solid and predictable.
Old Aug 31, 2006 | 02:17 PM
*starts researching more..*
Old Aug 31, 2006 | 03:37 PM
steven88's Avatar
Need A Light?
its worth it...i have it on my car, and stiffer engine mounts also allow better engine response...now the engine is completely solid when revved, it allows better pick up...theres also no more of that "bucking" action when lugging the car in 1st gear...everything is very solid...
as for racing, yes theres almost no more wheel hop...
Old Aug 31, 2006 | 04:00 PM
vq356sp's Avatar
El Mas Noob Del Org.
+1 I have ES motor mounts on my max and it definately feels solid.
Old Aug 31, 2006 | 04:58 PM
vsamoylov
hmm polyurathane or alluminum. lol
Old Aug 31, 2006 | 05:21 PM
jklx86's Avatar
hows it feel at idle? rougher?
Old Aug 31, 2006 | 06:43 PM
Yayomax's Avatar
still brewin'
If the mounts are bad, can the existing material be torn out the existing bracket and replaced with another type of compound that can be "poured in" and left a few days to be set or cured. Sort of an alternative to buying new mounts or inserts.
Old Aug 31, 2006 | 06:45 PM
steven88's Avatar
Need A Light?
there is a slight vibration at idle...IMO, its not bad at all...nothing like a real race car...and plus the small vibrations will let you know EXACTLY whats going on with your engine...i've had times where the engine was misfiring, knocking, etc....you can immediately feel it...and then you can go diagnose it...as opposed to soft mounts, where it might not pick up those irregularities
Old Aug 31, 2006 | 08:17 PM
the one on the cattman website only says 95-99 though
Old Aug 31, 2006 | 08:22 PM
steven88's Avatar
Need A Light?
if it's ES motor mounts...they will fit 95-03
Old Sep 1, 2006 | 12:20 AM
soo the ES motor mounts are the way to go?
Old Sep 1, 2006 | 12:36 AM
steven88's Avatar
Need A Light?
yes...10char
Old Sep 1, 2006 | 03:39 AM
nicks79's Avatar
And you only replace front and rear, no need to bother with left and right, correct?
Someone wrote here that Autozone has ES mounts...
Old Sep 1, 2006 | 04:52 AM
Puppetmaster's Avatar
Correct, just front and rear are to be replaced. Bear in mind you are replacing the inserts, not the entire mounts, although replacing the entire mounts but with the ES inserts is easier (but more costly).
Old Sep 1, 2006 | 04:55 AM
And for the search impaired:
http://forums.maxima.org/showthread....t=motor+mounts
Old Sep 1, 2006 | 07:22 AM
piotroosh's Avatar
sorry for a small hijack, but if anyone wants to sell their old mount (oem) i will be happy to buy it ;-)
I need the front one. ( i think ) theres a motor(?) inside and a wire with harness coming out of it. Mine got messed up and i need cheap replacement ;D
Old Sep 1, 2006 | 07:28 AM
The ATs have electronically controlled mounts that are different from the MTs. If someone with a MT replaces their inserts, its highly unlikely that it can be reused, let alone by someone with an AT. I could be wrong, but from my experience at least, the stock insert is pretty much always damaged/destroyed during the removal process.
Old Sep 1, 2006 | 10:10 AM
PoLo's Avatar
2-Wheelin it...
as far as AT's are concerned. the only difference is in that wire, that by unplugging it, you will get the CEL. although, if you do the swap like the MT's, and just get a cable tie, leaving the harness connected, you shouldn't get a CEL. the reaction from the harness is what tigthens up the motor mount. it shouldn't matter that it's not inserted, moreso that it's at least plugged in so the ECU thinks it's functioning as such.
Old Sep 1, 2006 | 10:39 AM
DrKlop's Avatar
Question, why are there only two mounts in the kit?
Old Sep 1, 2006 | 10:42 AM
PoLo's Avatar
2-Wheelin it...
4 total.
2 support the engine
2 more suppor it's movement
you don't need to swap the first 2 as they do nothing other than hold it up.
Old Sep 1, 2006 | 10:48 AM
DrKlop's Avatar
Originally Posted by PoLo
4 total.
got it, thanks!!
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
