Engine Dampener?
Engine Dampener?
Are there any companies that make one for the Maxima? I searched around, couldn't find anything. I was on mynismo.com and saw that they had one for the 350/G35. Does anyone know if this would possibly be able to be installed into a 5.5 gen? I know MMIs help wheel hop and such, but there was one made for the SE-Rs/Spec-Vs, and it practically eliminated such wheel hop when combined with the MMIs.
JClaw made the traction bars for the 4th gen, but could not adapt them to the 5G.
Best solution is a well-setup suspension. I NEVER get wheel hop....no matter how hard I punch it out of the hole.
ES control arm bushings, correct spring/strut rates, stage 2 LTB does the trick.
One other issue I have with this car, is the amount of engine jerking when you let off the gas in the lower gears. I read somewhere that the MMIs should reduce that, even though they will give a tiny bit of vibration during idle. Would something like this help as well though?
. Also, there is a hill by where I live, and every time it rains and I get stopped by the light right before the top, I hop like the easter bunny up the remainder of the hill. Makes me just want to
the car. And given I already found more debt than I can handle, any "less expensive" ideas on how to at least reduce this, if not eliminate it, would be greatly appreciated.
Yeah I feel you on the jerkness of the car. I think I am gonna probably do the ES mounts when the ones on the car fall. I'll just have to deal with the extra vibration in the cabin in order to cancel out some of the jerkness and all the movement by the motor......
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
