Are vq30 & vq35 5th gen catbacks interchangable?
Can I use an oem catback from a 5.5 gen on my vq30 5th gen? Any issues at all?
What about the cat, is it the same? Are the positioning of the o2 sensors the same?
Originally Posted by Stardust
the 2000 fed spec has an o2 after the cat, all the others do NOT
Originally Posted by kingrukus
So you are saying the OEM B pipe & OEM muffler from a 2003 fedspec will NOT bolt up to a 2000 Maxima fedspec?
If you have a FED spec 2000, you will need an O2 sensor bung after the main cat, which is a pretty easy job for any shop. That is of course, unless you get a b-pipe made for a FED spec 2000.
All b-pipes, rear sections, cat-backs, etc for 00-03s are interchangeable and will bolt up just fine. Just check to see whether your 2000 is FED spec or not for the purposes of figuring out whether you need the O2 bung.
Originally Posted by Puppetmaster
ALL 2002-2003s are CALI spec.
Originally Posted by CaTalyst.X
Pop the hood and look on the sticker, if it says it meets california emissions then its cali spec, if not...fed spec
Well it was built for Canada so I am assuming it is fed spec. Is there any way to tell for sure if it is?
4 O2 sensors = CALI
3 O2 sensors = FED
Instead of getting a bung welded in place, is there any reason why I can't just stick an old o2 to plug the hole up? Just curious...
Originally Posted by steven88
yes you can...
Well, one other question then....
Do 4th gen and 5th gen o2's use the same thread pattern? If so, I would just plug the hole with one of my old 4th gen o2s....
Hmm...
yes they do....
...why dont more people do this? is it because the o2 sensors protrude into the path of the exhaust too much, hence restricting airflow?
interesting...
i can answer one part however....if you're getting STOCK parts off a 5.5...then the bpipe will have NO hole...so you must bring it to a muffler shop to get one welded...
if you're getting aftermarket, it MIGHT come with a hole...my 5.5 bpipe came with 1 hole specifically designed for fed spec maximas...I never used it, but it came with one...
first, why dont u tell us what you're exactly getting? cuz from your original post, i can't tell if you're implying stock or aftermarket exhaust parts...
My understanding for the above setup, is that the 2003 catback will come with one extra bung which I will have to plug if I install on my 2000, correct?
P.S....I just realised I was mixing up the term "bung" & "plug".
I'm not quite sure why this is so hard to understand.
hes been a member for such a long time...
i realize 4th gen and 5th gens are different cars regardless...but to ask "can i use an o2 sensor to plug up the hole?" is just
OK, I am getting mixed answers here. One person says the 2003 has 4 o2 sensors. I am assuming 2 before the cat (y pipe, header area) & 2 after the cat (in the b pipe). And another person says that the 2003 will not have an extra bung. How many bungs does the 2003 catback have total?
I am not doing this for performance gains, I want to switch my aftermarket b & muffler back to stock for noise reasons.
About using the o2 sensor to plug a bung, I was asking because I have never done this before, and it seems almost like a "too good to be true" solution, so I thought I'd ask first...
Did I clear it up enough for you?
bottom line is...YES, it will fit completely fine....however, YOU WILL have to get an extra bung welded onto your 2003 catback...in order to accomodate the o2 sensor that your fedspec has behind the main cat...PERIOD
if you ask any further questions, then you should not be driving a maxima
^^^^^ There is your answer. NO CALI SPEC CAR HAS AN O2 AFTER THE CAT.
I had a bung welded in once and the shop put it in the wrong spot, so I plugged that hole with an old O2 and had them weld in another bung.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
