hesitating at first startup
Old Sep 11, 2006 | 07:48 PM
jettatdi's Avatar
My 2000 Max hesitated bad this morning and was knocking. Just got the car a few weeks ago and noticed it hesitating a little when first starting in the morning but thought little of it until today. It also knocks a little when first starting it up, any ideas whats going on here? it has 160k miles on it and otherwise runs damn good. Maybe plugs? knock sensor?
Thanks,
Old Sep 11, 2006 | 07:50 PM
alextothestars's Avatar
my pops' 00' gxe is starting to do it at startup. it has 80k on it. im thinking plugs.
Old Sep 11, 2006 | 07:56 PM
AceofSpds's Avatar
wat
any CEL's?
My car sorta does it at idle every now and then but its because of my coils.
Old Sep 11, 2006 | 07:59 PM
thats a valid point. 160k on factory parts is up there....i know my dads coils are factory and it has 80k and thats bad on its own.
Old Sep 11, 2006 | 08:15 PM
irish44j's Avatar
retired moderator
i'm tempted to not help since you have the verboten word "Jetta" in your username, but I'm in a good mood:
three things:
First: Change spark plugs at that mileage.
Second: Clean the throttle body...this will eliminate most hesitation problems. At 160K it must be dirty as hell...mine is grimy after every 10K miles.
Third: If still hesitating, replace (or clean) the MAF.
and there's always Seafoam!
Old Sep 11, 2006 | 08:44 PM
Mints33's Avatar
Any brand of throttle body cleaner you recommend?
Old Sep 12, 2006 | 06:01 AM
Love_00_Max's Avatar
Any carbonator cleaner will work, but I choose Valvoline Carb Cleaner. One other thing, don't just spay the soln onto the butterfly plate and beyond, take a lint free cloth, soak it with the cleaner and then use that to clean the plate and beyond it. There are threads out here that spraying the cleaner into the throttle body has messed up some IVAC and other gadgetry.
Old Sep 12, 2006 | 06:20 AM
Mints33's Avatar
Cool, thanks for the tips! I'll have to give it a shot after I get all the other stuff done, lots to do.
Old Sep 13, 2006 | 06:52 AM
jettatdi's Avatar
Well, I cleaned the throttlebody yesterday and also changed the plugs. It does run smoother, however now after paying much closer attention to the engine I noticed it does have a slight, steady knocking. MAF sensor?
Old Sep 13, 2006 | 12:46 PM
5thgenmaxima's Avatar
Did you check the oil level? Has it been changed recently??
Mine also has a relatively quiet knock at idle. Sounds like a soft rod knock. Just chalked it up to no big deal since it's way quittier than the lifters in my last car.
Old Sep 13, 2006 | 01:14 PM
jettatdi's Avatar
This morning the car took right off! Almost no hesitation at all! Great improvement. Just need to diagnose the little rod knock at idle.
msellas
Sep 23, 2015 09:16 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
bennuss
Sep 11, 2015 05:55 AM
