Need Help
Old Sep 13, 2006 | 08:38 AM
smokinmaxima03's Avatar
Need Help
Dash board meter lights are dead. Also when I turn on my headlights, my OEM (Not Bose) Stereo's light dies also. Does anybody know whats going on? Where is the fuses? I found some in the engine bay and some under the steering wheel but none says anything about dashboard light fuse. HELP
Old Sep 13, 2006 | 08:41 AM
OC guy's Avatar
2002 maxima se
does the car starts?
Old Sep 13, 2006 | 08:45 AM
yep everything is fine except the dash board lights are dead (with the headlights turned on or off) and the stereo lights (what track number I am on and how many minutes the CD has been playing screen) die when i turn on my head lights.
Old Sep 13, 2006 | 08:50 AM
OC guy's Avatar
2002 maxima se
could be your battery dieing down...if it was a fuse it would have been completely out of power with no lights. i am not sure as you said the car does start it can be something else beside battery. but i believe its not fuse.
Old Sep 13, 2006 | 11:16 AM
does anybody else knows or have had the same problem I have now?
Old Sep 13, 2006 | 07:28 PM
please somebody help before I go to the money hogging biatches (Dealership) for help!!!! My dash board lights are out and when I turn on my headlights the stereo;s lights go out but if i don't turn on the headlights the stereo lights are back on. This is all happening after I tried installing an amp to my stock OEM Stereo.!!!!!!!!!!!
Old Sep 13, 2006 | 07:51 PM
OC guy's Avatar
2002 maxima se
your amp is sucking all the power i guess....try to unhook the amp and see if it reacts the same, otherwise your battery is weak or you are having loose connection wiring. you may have messed with wires behind the stereo while installing amp.
Old Sep 13, 2006 | 08:07 PM
BLK2BLU's Avatar
Check your grounds
Old Sep 13, 2006 | 08:11 PM
yeah after noticing the problem, I un-installed the amp already bu tthe same problem is still there. I don't know where to start looking for ground wire I dont know anymore. I have been working on it most of today for like 6 hours now trying this and that and still nothing.....thanks though for your suggestions.
Old Sep 13, 2006 | 08:12 PM
Any more ideas or thoughts on how to fix this or should I just say F it and take it in for a check up?
Old Sep 14, 2006 | 12:38 PM
bump last try before taking it in.....any more ideas?
Old Sep 14, 2006 | 12:43 PM
OC guy's Avatar
2002 maxima se
Take it back to that amp shop where u bought your amp...and explain them your problem as u said it happened cuz of the amp. or have your amp installed from any electric shop and next day go back and complain about your electric issue. u will save money with dealer.
Old Sep 14, 2006 | 01:10 PM
GBAUER's Avatar
alternator. That problem seems to be the most common right now: Irish, then me, then about half the 5th gen forums....
Old Sep 14, 2006 | 01:41 PM
OC guy's Avatar
2002 maxima se
^ ya could be alternator...I forgot to mention that i have replaced my alternator cuz my 2k1 was dead on road with similar signs that you are getting. have your alternator checked to be sure.
Old Sep 14, 2006 | 01:52 PM
GBAUER's Avatar
Do the lights brighten when you rev your engine? If so, then it's probably the battery. If not, then it's probably the alternator. People try to make things too difficult now when diagnosing a problem.
