?? for Helios HID fog people...please step in..
Old Sep 14, 2006 | 02:59 PM
djbonsu's Avatar
ok...ok....so i got my fogs to work great!!...however, it seems that my foglight housing gets fogged up with some kind of residue when i ran them initially!! is this normal??..i have drilled the back housing for the wires to pass thru and siliconed it for a good seal...both of my foglight housing have this cloudy looking residue on the inside of them. has this happened to anyone?
Old Sep 14, 2006 | 04:03 PM
djbonsu's Avatar
i guess this hasnt happend to anyone...
Old Sep 14, 2006 | 04:35 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
I would assume that it's from the heat of the bulb on the cheap azz plastic inside. Not to worry though... You should be alright.
Old Sep 14, 2006 | 06:37 PM
djbonsu's Avatar
Orgullo,
I thought that HIDs operate cooler than halogen bulbs? My lenses were clear before I out the kit in plus that is a brandnew assembly! I am ordering new asemblies from eBay because my passenger light is a lot worse than this one. Just want to make sure that this doesn't happen in my new assemblies.
Old Sep 14, 2006 | 06:53 PM
VaporHead
Clean the inside out and apply some shaving cream to the lenses to prevent fogging. No joke.
Old Sep 14, 2006 | 07:18 PM
Dr. Roy's Avatar
did you get any silicone on any areas that get (realy) hot? silicone can fume and fog up lenses.
Old Sep 14, 2006 | 08:02 PM
n3985's Avatar
大陆弟弟
Are you sure it isn't just some simple condensation?
Old Sep 14, 2006 | 09:01 PM
Orgullo's Avatar
Originally Posted by djbonsu
Orgullo,
They are cooler but hot none the less. I thought you were refering to the reflective part... not the lenz itself. Next would probably be what the Dr. said. I'm not sure man...
Before you buy new ones you should try and clean them again and re-seal them. That's a lot of money for trial and error again.
Old Sep 15, 2006 | 08:44 AM
00MaxSE's Avatar
Pointy Elbows
I bought mine used from Ammi and the lenses are all fogged up too.
Old Sep 15, 2006 | 09:07 AM
djbonsu's Avatar
thanks guys, however i tried opening the housings by heating them up but to no avail, i could not open them up....how can i clean them w/o opening them??....i think it might have been the silicone dr. roy....how do i avoid this problem again??...i just siliconed the back housing.
Old Sep 15, 2006 | 11:11 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
clean them up, dry them real good, get into a walk-in fridge with the fixtures and re-seal them with some high-temp Silicone Sealer. Leave the fixtures in the fridge for a few hours so the air inside the fixture has the least amount of moisture possible. only do this if you're nuts or a manager of a fast food place. in theory, it'll work best.
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
