is this possible??????
Old Sep 15, 2006 | 07:06 PM
dafertilizer's Avatar
I have noticed that my 2k A/T max has been losing signifigant top and bottom end..
I noticed this high pitch sucking sound from my pop-charger intake (sounds like a big air leak in a tire) but it stops exactly at 2500 RPMs,
Then when I give it WOT the RPMs shoot up to 5000 and you can hear the VIAs open, and the RPMs move very slowly to 5800-6000 where it finally shifts.
Now heres the really strange part; The car is not really accelerating???
Is it possible for the torque converter to not be transferring the power to the tranny? can the tranny slip without a noticable high rev in the RPMs and a thunk into gear?
Old Sep 15, 2006 | 07:44 PM
VaporHead
Maf!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Sep 15, 2006 | 09:15 PM
I know it sounds like it, but I just put in a Brand New MAF 11k miles ago.
Old Sep 16, 2006 | 08:41 AM
97Se5spd's Avatar
Id say MAF too. Its possible its already bad???
Old Sep 16, 2006 | 08:57 AM
can a MAF go bad in only 11K miles?
Old Sep 16, 2006 | 10:59 AM
doc2278's Avatar
Doctor D I presume???
shouldnt go bad after 11k frank. I would suspect apossible vaccuum leak somewhere in your system. that can also cause a loss in power. any other symptoms with it? the high pitch around 2500 rpm is normal in maximas with the popcharger, I get it too.. possible torque converter as you said too ( more so suspicious that it is torque converter than anything else).
Old Sep 16, 2006 | 11:43 AM
xnyc's Avatar
make sure you have the right amount of ATF. sounds like your low on tranny fluid
Old Sep 16, 2006 | 01:49 PM
fluid is at perfect level, and still that nice red color (just changed with mobil 1 about 7k miles ago)
