Yes I searched....tire question 235/50R17 vs 225/50R17
Now I would like to think I know a little about tires. Currently I am running 235/45R17. I am down to 4/32nds of tread and winter is coming. I want to go back to 50 series tires as I am older and dont care as much about performance as I do comfort (I know it doesnt make that huge of a difference, humor me) but I like the 235 size.
Should I have any problem going fom a 45 to a 50, after all it is the ratio of the width of the tire to the sidewall height. According to the miata chart I am only altering by .2 inches from what the 225/50s are. I have been running the 235/45 for almost 3 years.
Your thoughts on moving to the 235/50 from the 235/45 on the OEM rims.
You can run 235/50 without issue......per 5th gen FAQ
http://forums.maxima.org/showpost.ph...5&postcount=71
Originally Posted by spark plugs.
225/50 = 112.5mm sidewall
235/50 = 117.5mm sidewall + 10 mm wider track...you might need to start worrying about rubbing.
Thank you I did not see that, appreciate the response.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
