Installed SAFC II and dynoed it
Old Sep 22, 2006 | 04:14 PM
maxspeed96CT's Avatar
The original VQ...
K , i installed the safc 2 today and had it dyno tunned, im pritty happy with the results, my only mod is a pop charger and now the afc.
Base run is with pop charger HP:207.64 and TQ:209.14
afc and after tunning HP: 217.32 and TQ: 225.46
Car feels the same except 1st gear tires used to just break loose when i pinned it off a roll with my pilots, now it spins alot more and i get some crazy wheel hop...
My friend also dynoed his 05 g35 sedan 6mt with a intake , got 251 hp and 217tq.
The dyno cureves looked almost identical but around 5k my hp starts to drop and his keeps climing.....
After i raced the g35 off a 1st gear roll and i had him up to the top of second gear, then he pulled and by 120 ish i was at his back bumper, then we went off a second gear roll and same thing, he just slowly pulled away ...
Old Sep 22, 2006 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
Sweetttt....Got the run files, if so can you plase send them to bizzy1999@hotmail.com,
So this is POP charger and SAFC as the only mods?
Old Sep 22, 2006 | 04:19 PM
steven88's Avatar
Need A Light?
GREAT #s if you ask me...just a pop charger and AFC FTW!
Old Sep 22, 2006 | 04:20 PM
The original VQ...
yup only mods are pop charger and safc
do the numbers look right?
srry man all i got is a piece of paper and i scanned it and loaded it up....no files
tomoro ill post up the comprison of the g35 and the maxima
Old Sep 22, 2006 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
This is another indication that AFC + intake is FTW.....An intake is not complete w/o A/F tuning, what did you shoot for (AF ratio)??
Old Sep 22, 2006 | 04:30 PM
The original VQ...
the guy told me what he changed it to but i fogot, i think 13 somthing or 14 something???
I dunno, my knowledge about tunning and a/f rations is very low.... I can just take stuff apart and pout it back togther
He said he couldnt realy squeeze more out cause im stock as far as exhasut and etc...
Old Sep 22, 2006 | 07:04 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i would say those are strong numbers for the mods. im looking forward the the comparison dyno with the g35 numbers. i have seen some that inclined me to believe that both hp and torque were overated but from what your friend put down, it seems pretty inline with infiniti's numbers.
Old Sep 22, 2006 | 07:29 PM
NmexMAX's Avatar
dot dot dot ...
High hp low tqw..
My last dyno I didn't make much tq, but only lost 2 whp from 6k - 7k..
Old Sep 22, 2006 | 11:28 PM
808MAX-SPEC's Avatar
OMG! Pop charger and SAFC?!!
Old Sep 23, 2006 | 05:58 AM
shysmax's Avatar
not knowing much about tuning and playing with a/f's can be VERY dangerous. a/f of 13 and 14 - where? if at high throttle, u're running close to stoich. How much fuel did he pull? At what % will the ECU pull timing? I recommend u ask for a dyno with a/f's on it. I'm still learning about tuning my supra turbo, but we don't tune past 11.5 generally speaking, otherwise KABOOM could be in the veyr near future. Maybe with n/a's u can go closer to stoich?
ShysMax
Old Sep 23, 2006 | 07:03 AM
The original VQ...
ya i dunno what im doin, the place i went to is know for doing awsome tunning and building some sick cars, they know their stuff.
The guy told me he couldnt tune my car much cause its bascily stock.
I told him to squeeze alittle more out of it and keep it safe.
Old Sep 23, 2006 | 07:18 AM
sloppymax's Avatar
ShysMax
ive got mine tuned to around 13.0-13.5. during the street tune, there was several times where it was 14 flat with no detonation but it was pulled back just for caution sakes. when boost comes into play, the a/f is most always richened.
Old Sep 23, 2006 | 07:58 AM
A33 VQ30DEK's Avatar
if this works so great on the 3.5 L maximas... how about the 3.0s with some mods? Will i gain high numbers like that?
Old Sep 23, 2006 | 08:35 AM
steven88's Avatar
Need A Light?
mod for mod, the 3.5L will always be higher...but if you slap on I/H/E and S-AFCII to a vq30dek, there could be a possibility u still fall short from maxspeed96ct #'s...
Old Sep 23, 2006 | 10:09 AM
sloppymax's Avatar
depends on your current a/f. mine was perfect back when i had my cattman y pipe. almost 13 across the range that was dynoed. with headers on, it was running rich. i gained around 8-10whp through the range and about the same for torque with my vafc2 tuned to 13-13.5
Old Sep 23, 2006 | 10:38 AM
FriscoMaxima's Avatar
sorry for ignorance, but how exactly does SAFC control the air/fuel mixture?
Old Sep 23, 2006 | 12:00 PM
NmexMAX's Avatar
dot dot dot ...
Pulls/adds MAF V... in turn altering ECU feedback, pulling or adding fuel.
Old Sep 23, 2006 | 12:19 PM
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
+1, dude i want a 5.5 gen maxima
Old Sep 23, 2006 | 03:48 PM
The original VQ...
does anyone here have adobe photoshop?
I have the g35 and maxima dyno comparisions, but my friend made them some weird format, i think its photoshop (.psd?)
if any one can change it to a reg jpg that would be cool so i can post it up, aim me or email me at maximaspeedct@yahoo.com
Old Sep 23, 2006 | 06:05 PM
kingrukus's Avatar
no more maxima...
Damn I should keep my S-AFCII.
Old Sep 23, 2006 | 06:49 PM
shysmax's Avatar
"Street tune" does that mean u tuned it on the street with a WB? Or did you tune it at the dyno for the street? If 13's are considered safe #'s on N/A's sounds like you have a nice setup. Any dyno #'? What are your mods?
ShysMax
Old Sep 23, 2006 | 06:58 PM
steven88's Avatar
Need A Light?
street tuning = means you are on the street, tuning your car...aka, real world conditions...hood is closed, more load on the engine, aerodynamic resistance, sometimes hotter weather (less o2)
dyno tuning = means you are tuning on the dyno....this can be favorable to some...it's safer than street tuning...becuz you won't get caught by the police.....also your hood is open, and the facility is usually cooler than outside temps...therefore more o2 within the area...a huge fan is blowing cold air (most dyno shops carry a huge fan)...can't think of anything else
Old Sep 23, 2006 | 07:04 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
so wait...you never mentioned a wideband to show if you're actually making correct adjustments to the air/fuel ratio.
Old Sep 23, 2006 | 07:05 PM
steven88's Avatar
Need A Light?
oh yeah...well i don't think i need to mention using a wb02, do I? i mean, what else would you use to read air fuel ratio?
Old Sep 23, 2006 | 08:23 PM
sloppymax's Avatar
ShysMax
steven explained the street tuning above. i have a couple of dynos floating around the org but the most recent i was having issues with my fuel pump (it would not hold pressure over 6krpms). i put down around 197hp but i cannot recall the torque off my head. my low and midrange torque is pretty low due to the powervalve in my manifold being taken out. that provides for the best hp and moving my peak torque into higher rpms. my power mods are intake, headers, b pipe, vafc2 for tuning and other things that help/might help are an udp, 15lbs wheels, some weight reduction and fpr with the pressure bumped up and taken back with the vafc2 for improved timing. ive got the fuel pump replaced and put on a 350z lower temp thermostat so im ready to dyno again. i would guess im over 200whp as it stands but only the humblemaker knows for sure.
Old Sep 30, 2006 | 09:38 PM
The original VQ...
Graph comparing a 05 G35 sedan sport 6mt dyno and a 02 maxima 6mt dyno
(sorry for the black and white......)
Old Oct 1, 2006 | 08:02 AM
joebangaa's Avatar
WTF that's some nice high end
Old Apr 4, 2007 | 02:45 PM
Fastmax05's Avatar
"Ok,Whats next?!?!"
SafcII wow great numbers...
I ahve a fujita cai and magnaflow muff's ... Will adding a sfc with just these mods produce decent gains???
How much shuold a place charge for install???
Old Apr 4, 2007 | 02:54 PM
DOHCtorJT's Avatar
Yeah more than likely you'll get a gain from tuning with the SAFC. Installing it yourself would be my recommendation, it's only a few wires and it'll help you understand what you're doing and how it works. But if you must pay, probably an hour worth of labor (average $65-80/hr) unless you want some trick mounting or other custom stuff.
It's not a toy by any means....dyno with a/f readings or wideband o2 sensor should be mandatory. I've known a few people who got too greedy and cracked pistons from detonation...(not maxima's though)
Old Apr 4, 2007 | 05:16 PM
absoundlab
not bad at all
a gain of 9.68 hp and 16.32 tq
I have a vafc-II that im waiting to get installed I cant wait
Old Apr 4, 2007 | 05:25 PM
NmexMAX's Avatar
dot dot dot ...
I thought I already told you this?
It depends on your current AFR.
Do you have the runfiles for these runs?
Old Apr 4, 2007 | 05:48 PM
twitch579's Avatar
Can anyone please link me to where I can get this SAFC2? I cant find it on the internet.
ALso can someone link me to the Pop Charger???
I dont know anyplaces to get stuff for my Max.
Old Apr 4, 2007 | 05:52 PM
NmexMAX's Avatar
dot dot dot ...
www.ebay.com
http://www.jimwolftechnology.com/
www.stillen.com
You suck at teh search.
It took me less than a minute to find numerous SAFCII links.
http://www.importperformance.com/ape...criptions.html
Check the classifieds on here.
Old Apr 4, 2007 | 05:56 PM
twitch579's Avatar
THanks!!!!!!!
Old Apr 4, 2007 | 06:02 PM
NmexMAX's Avatar
dot dot dot ...
Why not get a NEO or VAFCII?
Old Apr 5, 2007 | 07:18 AM
03BlkSETE's Avatar
Hah! Prepare to get a dozen more questions now.
Old Apr 5, 2007 | 07:27 AM
NmexMAX's Avatar
dot dot dot ...
That was alomost the point, since 72% of the people on here have no clue what these are, nor how to use them.
BTW, when are you dynoing again
Old Apr 5, 2007 | 08:08 AM
sooner02r1's Avatar
I raced a buddy of mine's g35 sedan and I pulled him. He jumped on me out of the hole and then I just walked past him and had about a car length at 130mph and he was stock and all I had was an intake.... But this g35 was an auto and I am a 6 speed, maybe that had something to do with it?
Old Apr 5, 2007 | 08:17 AM
NmexMAX's Avatar
dot dot dot ...
.... ok.......................
Old Apr 5, 2007 | 08:22 AM
Puppetmaster's Avatar
There is a forum for crap like this, please use it:
http://forums.maxima.org/forumdisplay.php?f=78
I also don't see how this has anything to do with the current discussion.
