I need help with ES bushings
I have a 2003 Maxima, and i want to get the front Sway bar bushing set, but i Dont no the size. Is it 22 or 23mm. The people from ES dont have a clue.
I also want to get the subframe and the front links. Does anyone have the sizes or # for them thanks.
I beg to differ - in fact, I found HUGE difference after replacing OEM FSB bushings with ES ones.
The steering wheel has became very "live" - once taking it off-center, it goes back to the center with vigor. During turns, now it takes an effort to hold the steering wheel; before the ES bushings the steering feel was very "vogue"...
This was an excellent mod for mine '02 6sp with 90K on it.
Eugene
Eugene
No need for an alignment. In response to the yvfed1, I would assume the reason he saw a noticable change (where I did not) was due to the high mileage. I changed mine around 30k (yvfed1 changed his at 90k).
When I put the OEM and ES bushing side by side they had the same look and feel. I did not find the OEM one to be less stiff than the ES bushing.
Greasing the ES Sway Bar Bushings
Eugene
Eugene
Did you buy the set with the grease fitting. Are they easy to get a grease gun into them to grease them? How often do you need to grease them?
thanks
Vic
knight_yyz
Nov 1, 2015 01:34 PM
ColdCananda
Sep 20, 2015 10:45 PM
