03 SE Question
Old Sep 25, 2006 | 11:40 AM
3ZDUZIT's Avatar
03 SE Question
Has ne1 noticed that their 03 Maxima burns oil at an exaggerated rate? I have owned several Nissans over the years. None have burned oil the way my Max has. With the other Nissans they burn little or no oil between my 3k oil changes. The Max appears to burn a quart every 1.5K. I am using Mobil 1 10/30. Any thoughts?
Old Sep 25, 2006 | 11:47 AM
Redstone's Avatar
I have'nt noticed anything on my car. I had a bad oil pan which I replaced a few months ago and I was loosing oil for obvioius reasons, but since I put the new one on the oil level stays almost the same between oil changes. I drops a little, but not anything near a whole quart. I currently have 85000 miles plus on the car. How many miles do you have on you car now? I think it is common for most cars to burn a little when the engine has high miles.
Old Sep 25, 2006 | 12:11 PM
3ZDUZIT's Avatar
I only have about 40K on it.
Old Sep 25, 2006 | 02:20 PM
Redstone's Avatar
At 40k you should'nt be burning that much oil. Did you check for leaks etc like any oil spots where you were parked overnight. I don't know if this has any revelance to the topic, but Nissan recalled a bunch a Altimas and Sentras earlier this year for the excessive oil comsumption and those were never cars than ours some only a few months old. The were manufactured between certain dates. Other than leaks I don't know what else to recommend other than making sure you check your oil level frequently just in case. Anyone else with any helpful info please chime in.
Old Sep 25, 2006 | 03:46 PM
SoonerFan's Avatar
Cletus
newbies, its a very common problem. look around....there are PLENTY of threads
ive getting mine worked on under warranty. they are trying to pinpoint the problem. so far they have changed the PCV valve and the valve covers.
Old Sep 25, 2006 | 03:47 PM
SoonerFan's Avatar
Cletus
my story http://forums.maxima.org/showthread.php?t=486215
Old Sep 25, 2006 | 05:44 PM
GBAUER's Avatar
they tried to blame the valve cover gaskets on yours too? They're reaching! Can I put $20 on the rings?
Old Sep 26, 2006 | 10:55 AM
bladerunr's Avatar
I have 59K on mine and it has burned oil for over a year. Good luck.
Old Sep 26, 2006 | 11:12 AM
Colossus's Avatar
105k on my '02... doesn't burn a drop between 5,000 mile changes.
Old Sep 26, 2006 | 11:30 AM
NmexMAX's Avatar
dot dot dot ...
03 SE
76,500 mi,
Build date 10/02
No burning/consuming
Old Sep 29, 2006 | 10:06 AM
zenjia 03merlot's Avatar
i burn 1 to 1.4 quarts per 3k mi change intervals. haven't paid attention to the rate at which it burns, will check oil at 1500 mile mark for this last change. mobile 1 synthetic 5-30, about 30K on car
Old Sep 29, 2006 | 11:33 AM
DAP's Avatar
DAP
03 SE with 26K and no oil consumption issues. Maybe you guys didn't break your engines in properly.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
