rattling sound?
Old Sep 26, 2006 | 01:17 PM
opanick's Avatar
rattling sound?
when i take off sounds like there is something rattling around in my exhaust pipe, any ideas??? only when im taking off or rolling off a stop sign
Old Sep 26, 2006 | 02:09 PM
MaxSE-R's Avatar
you might be low on oil, check your oil
Old Sep 26, 2006 | 03:40 PM
opanick's Avatar
i just did my oil change the other day and still hearing it
WooHoo!!!!!!!!! This is my 100th post!
Old Sep 26, 2006 | 03:44 PM
SPEEDY6's Avatar
Beech Man Whore Slapper
It also might by your cat. After 115,000 miles on my Max, my cat is finally shot!
When I roll to a stop is when the rattling sound comes along.
Old Sep 26, 2006 | 04:03 PM
sanmiam's Avatar
See if you can hear it at idle (crawl under and have someone rev the engine a few times) Listen for the rattle, or any exhasut leaks (poofing noise) If you can great - easy to identify. If it only can be heard under load (aka - while driving) than most likely the baffeling inside either the cat or the muffler is bad and rattling.
Old Sep 26, 2006 | 06:32 PM
DJ2Max's Avatar
The same thing happenede to me and i found out that it was caused by a hole in the pipe of the rear section.
Old Sep 26, 2006 | 07:13 PM
jkayca's Avatar
I had a loose heat shield above the cat that caused a rattle. Just had the mechanic tighten it up and haven't heard boo since.
Old Sep 26, 2006 | 08:42 PM
bugbite77's Avatar
That what i thought, common. good to hear you had a simple fix.
Mahmuth
Aug 16, 2024 08:23 PM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
