Any clue on tightining the steering wheel....
Old Sep 26, 2006 | 08:41 PM
TopSpeedNY's Avatar
I have a question Guys, Any clue on tightining the steering wheel on the 00-01 SE any parts that may rely on it mines is too loose.
Regards,
Mike
Old Sep 27, 2006 | 11:35 AM
TopSpeedNY's Avatar
!bumpity Bump
Old Sep 27, 2006 | 12:02 PM
Mints33's Avatar
Is there play in the steering wheel?
Old Sep 27, 2006 | 12:07 PM
TopSpeedNY's Avatar
what you mean play ?
Old Sep 27, 2006 | 12:28 PM
deftflux's Avatar
I would check the tie rods. The bearings could get sloppy from wear and you don't want them to go out completely while you're driving...
"Play" would be if you can move the steering wheel somewhat before the car actually starts moving that way. It's best noticed when you're going straight. If you can steer left, right, left, right, etc. just turning it a little each way and the car makes absolutely no change in direction, you've got play.
If you don't have too much play, I have a 2000 and I've noticed my steering is naturally a little like that due to the power steering. I'm tempted to get an underdrive pulley for the power steering pump to make the steering stiffer.
Old Sep 27, 2006 | 05:09 PM
TopSpeedNY's Avatar
ill check on that thanks bro.
Mike
Old Sep 27, 2006 | 06:22 PM
sascuderi's Avatar
Ive noticed the same thing on my 2000 I30 with 47K miles. Seems almost like the power stearing needs to be turned down a notch or two.
Any way to reduce the power stearing boost without changing the pulley?
Old Sep 27, 2006 | 07:06 PM
TopSpeedNY's Avatar
sascuderi how can this be done thanks bro,
Mike
Old Sep 28, 2006 | 01:00 AM
getbigtony's Avatar
i don't think that can be done.. we use steering racks. if we used a steering gear, i believe, then it can be done
Old Sep 28, 2006 | 05:31 AM
TopSpeedNY's Avatar
where can i get a steering gear getbigtony?
thanks,
Mike
Old Sep 28, 2006 | 10:39 AM
phong's Avatar
I think what you're trying to say is the power steering system is over-assisting. If that's the case then there's really nothing you can do about it. If you want more steering feel, I guess you can add wider tires or a limited-slip differential, but that's just plain stupid. Also, check your tire pressure; if they're over-inflated it could cause your steering to feel "loose".
But, if your steering wheel is actually loose - i.e. you can easily turn the wheel with the engine off, then you need to bring it to a mechanic. Better yet, have it towed.
Old Sep 28, 2006 | 01:03 PM
TopSpeedNY's Avatar
no its not loose on engine off and what are the clicking noise in the steering while turning left or right any clues on that?
Regards,
Mike
Old Sep 28, 2006 | 04:39 PM
TopSpeedNY's Avatar
!bump !bump
Old Sep 29, 2006 | 03:19 PM
TopSpeedNY's Avatar
!bump !bump
Old Sep 29, 2006 | 03:21 PM
TopSpeedNY's Avatar
Can the crank pulley make it better and changing the belts ....
Thanks guys,
Mike
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
