can an OBDII scanner pick up codes that dont throw CEL?
A friend of mine has a 5th gen which was recently showed a CEL. However, it was only for one code. When they hooked it up to thbe CONSULT 2, it detected codes for a dead knock sensor and dead rear o2. The dealership he is dealing with is trustworthy, so we both know they aren't taking him for a ride.
My question is, can a regular OBDII scanner detect items which are not throwing a CEL, or can only the Consult tool do this?
That would be me. Things is I knew about the o2 from before and that never threw a code. Went in to get coils replaced, code gone but knock still throwing a code as well (no engine light on dash)
Originally Posted by jvienneau
A regular OBD2 scanner will show all codes, even those not turning on the light.
No, it won't. A "generic" OBDII scaner must show everything that regulations mandate, that's it. Most of if not all of the sensors a generic scantool can read are emissions related stuff. Nissan doesn't have to allow access to most non-emissions stuff thru generic protocal. Even with the new CAN protocal which is mandatory, it's not required. Scantronics, snap-on, Vetronix, ETC and the vehicle manufacturers would lose alot of money if everything was accessible. All information will never be accessible thru generic protocal, the special interest groups are just way to big.EDIT: Basically (IIRC) if the MIL light comes on, then generic scantools will show the code.
Ah, this throws a twist into things. What I will do is get it scanned by an generic OBD II scanner to see what it pulls. Right now I have no CEL, so if it pulls nothing then Ill take it to my dealer and get it scanned again and see what happens.
Even the Snap-on scantool sells Nissan specific programming for their scantools.
Don't let them charge more than 1/2 hour labor for pulling the codes though. If you're a regulaur customer and on good terms with the service adviser you may even be able to talk him into having one of the techs check for codes for you. (Show up in the afternoon around 2:00-2:30 when most of the work is done for the day, but the techs aren't ready to go home yet.) If they want to charge you 1/2 an hour to do it, then ask the tech to bump your idle timing up while you're there.
Most shops have an aftermarket scantool and have the ability to find everything. Vetronix made the consult II for Nissan and they sell disks compatible with their Mastertech, Tech 2, etc that will read everything.
Mar 12, 2020 12:06 AM
that's how I found out my MAF was dying..
