Drivers side window - does not open
Old Sep 27, 2006 | 01:57 PM
emhc1999's Avatar
So I took off the door, removed the connections and reconnected. All windows open except the drivers side window. When I try to open it I hear a clicking noise from the drivers side control unit.
Question - is there any easy way to figure out if it is the motor or the control unit/electric connection?
emhc
Old Sep 27, 2006 | 02:14 PM
VaporHead
Test the connector going into the motor, if you have 12vDC to it, you have a bad motor.
Old Sep 28, 2006 | 08:59 AM
BewstAdd1ct's Avatar
no..
the regulator may also be binding. try pressing the reset switch and relearning the window stops, it may be something as simple as that. dont go replacing crap just because...
its pretty much obvious youre gettnig power to the motor, otherwise the internal relays wouldnt be clicking, i wouldnt even bother with that step of checking power.
Old Oct 9, 2006 | 05:57 AM
emhc1999's Avatar
OK- so I tried the reset switch and that worked for a day it was operating fine. It was smooth, as good as new. Then it stopped working again and the reset doesn't work. So I am to assume it is the switch or the connection?
Thanks for your help Bewstadd1ct
MAXSE5SPD
Sep 17, 2022 04:00 AM
AcuraLegend
Sep 22, 2015 04:22 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
shaunkey1
Aug 18, 2015 10:09 PM
