Weird Intermittent Sunroof Issue
I have a 2000 Maxima SE with a power sunroof (2 switches: auto-open and hold to tilt). For some reason the open switch, when held to open, only opens 2" at a time and stops. Then i have to take my finger off the switch and hold it again, 2" again & repeat until it's open.
The strangest part of this, is that the open switch will do the same thing as the tilt switch and the tilt switch will do the same as the open switch (it will open fully 2" at a time and it will tilt and untilt when it gets to the closed position), almost as if they've become one switch.
Anybody ever see this? I'm not certain if it is the switches themselves but I feel like it an issue with a relay or something like that.
Good luck... Ive reset the the system (unplug the batt)... taken the relay out, and plugged back in... purchased a new switch from nissan ($50)... and still nothing. Although, i wouldnt b discouraged, almost everyone else on the org solved their prob. by unpluggin the batt. for a while, just didnt seem to work for me. You should try it, i think the concensus was like 45 minutes or so, then hook the negative back on. G/L
Mar 12, 2020 12:06 AM
pktaske
May 6, 2016 07:49 AM
mikeg75
Nov 30, 2015 05:12 PM
pktaske
Sep 4, 2015 08:40 AM
