rigged up a CAI...is this safe?
Old Oct 2, 2006 | 02:59 PM
96SEsleepa
i got a place racing intake pipe for a 4th gen, used a dremmel and cut the pipe down about 7 inches.
slapped on a filter and two cuplets and this is what i got..
i figured that it would suck in cold air right through the grill.
or am i wrong...
and i painted my grill black...what do yall think??????????
Old Oct 2, 2006 | 03:05 PM
96SEsleepa
Old Oct 2, 2006 | 03:07 PM
irish44j's Avatar
retired moderator
looks good to me....
Old Oct 2, 2006 | 03:12 PM
Dave H.'s Avatar
If it is right behind the radiator, it may actually get warm air that has been heated by the radiator as the air passes through. But it probably is cooler than where it would have been if you didn't do anything to it.
Does that make sense?
Old Oct 2, 2006 | 03:20 PM
96SEsleepa
yea makes plenty of sense ...thanks man
Old Oct 2, 2006 | 03:24 PM
HotshotVQ35's Avatar
CIA? you mean CAI? and its not
this is better, but still a WAI..
Old Oct 2, 2006 | 03:29 PM
SoonerFan's Avatar
Cletus
thats looks fine..but not a CAI
Old Oct 2, 2006 | 03:54 PM
illlojik's Avatar
I C U
CAI(cold air intakes) run down into fender and draws in cool/cold air. What you have is a ram intake or a warm air intake. Sure it's closer to the outside, but you'e still drawing in warm air from the engine bay. Other that that, it looks good. Good job
Old Oct 2, 2006 | 04:02 PM
n3985's Avatar
大陆弟弟
Why not put the stock snorkle back in? Cut it shorter so the opening is right where the filter is?
Old Oct 2, 2006 | 04:05 PM
SoonerFan's Avatar
Cletus
that snorkle does nothing
Old Oct 2, 2006 | 04:08 PM
808MAX-SPEC's Avatar
You could try putting a heat shield, but I'm not sure if it's really going to help let alone fit since the filter is closely fit between the battery and engine.
http://cgi.ebay.com/ebaymotors/AIR-F...QQcmdZViewItem
Old Oct 2, 2006 | 04:10 PM
irish44j's Avatar
retired moderator
true "CAI"
Old Oct 2, 2006 | 04:11 PM
GBAUER's Avatar
actually, it's not OK. Here's why: there's a hose that runs from the intake piping to the valve cover to allow air into the valve cover during vacuum conditions. The computer expects this air to enter the valve cover and the MAF tells the computer how much air is going past it. This means that during certain times, the ECU thinks theres less air going into the combustion chamber than there actually is. This will cause the engine to run lean. Now, the O2's tell the computer that the engine is running lean, the computer gets conflicting information and starts to act funny and eventually goes into a safe air/fuel mixture taking away power. I've actually experienced it myself. The solution is to run a hose from the valve cover (you took one off it) into the intake pipe between the MAF and the throttle body.
Old Oct 2, 2006 | 04:12 PM
GBAUER's Avatar
I'm going to have to go ahead and disagree with you. Please be reading my post above and become learned, my son...
Old Oct 2, 2006 | 04:19 PM
irish44j's Avatar
retired moderator
George, isn't that the hose just downstream of the MAF in his pic? The PR has an attachment point for it....
btw, did you put the new wheels on yet?
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
maybe its just the picture but it appears like the upper radiator hose is touching the filter. that hose gets quite warm.
Old Oct 2, 2006 | 04:23 PM
96SEsleepa
no the hose is not touching the filter...
in fact the filter is sitting right behind the fan..
Old Oct 2, 2006 | 04:31 PM
96SEsleepa
u seem to have a point..
thanks man. really appreciate it.
so what about a breather filter to put on it, would that do any justice?....probably not huh?
Old Oct 2, 2006 | 04:44 PM
GBAUER's Avatar
That's how I found out the hard way... don't do it!
Old Oct 2, 2006 | 04:50 PM
GBAUER's Avatar
Yep. That's the one. It's not connected by the looks of the pics.
Yessir! I'll take pics and post them when I get over this damn cold. I also got all :narted: up and threw in a 10" X-Plode sub, 4 channell X-Plode amp, two 6-1/2" X-plode speakers up front and two 6-1/4" inifinity reference speakers in the rear doors. sounds as good as it looks now.
irish44j's Avatar
retired moderator
that bad, huh?
Old Oct 2, 2006 | 04:51 PM
irish44j's Avatar
retired moderator
what, you can't walk in to your swanky garage and take a quick pic, just for me???
Old Oct 2, 2006 | 05:05 PM
super6's Avatar
looks like the vacume hoses are disconnected???
Old Oct 2, 2006 | 05:41 PM
GBAUER's Avatar
To answer your question: no. The cameras upstairs, my nose is running faster than a a 5.5 gen at WOT, I'm sneezing like an SOB, my ears are so stuffed that all I hear is basss, the car is outside in the garage, it's cold out there and my dog is laying on my lap and she won't let me move and my vagina hurts...
I'll take a pic with my cameraphone and send it to you tomorrow if it'll make you feel better! But, just to let you know, it looks damn good now. I've gotten "the nod" from a guy with a really nice S-2000 and a modified 5th in B-more (rims, clears and lowered, but not anybody from teh .org...). Never got nods before. I guess deh see me rollin'....
For the rest of you, I got these:
and put them on this:
pics to follow as soon as this damn cold goes away and I can clean my car again!
Old Oct 2, 2006 | 05:43 PM
GBAUER's Avatar
see my first post.
Old Oct 2, 2006 | 05:57 PM
Derrick2k2SE's Avatar
Could you post a picture of the black grill with the hood closed? I'm considering doing that on my car (same color). That might help me decide. I blacked out the HID housings and cleared the amber lens last week. The black grill might finish the look.
Old Oct 2, 2006 | 06:02 PM
irish44j's Avatar
retired moderator
how heavy are they? Gonna use them for autocross in 2 weeks?
Old Oct 2, 2006 | 06:19 PM
GBAUER's Avatar
The bare rims are 20 lbs each (not light, but lighter than stock). And, yes, I'll be sporting them.
Old Oct 2, 2006 | 06:38 PM
maxspeed96CT's Avatar
The original VQ...
is it ok for that hose to just hang there??
I got a pipe i can use but i dnt wanna leave the hose hanging.
that looks like a semi cold air btw
Old Oct 2, 2006 | 06:41 PM
GBAUER's Avatar
I hope I stated it enough times for everyone.
Old Oct 2, 2006 | 07:50 PM
P. Samson's Avatar
Not withstanding the engine control issue, you're sucking unfiltered air into the top of the engine (camshafts etc.) and crankcase areas at small throttle openings (low power) and blowing out pollutants into the atmosphere at the larger throttle openings (high power).
Old Oct 3, 2006 | 02:30 AM
Yayomax's Avatar
still brewin'
actually, it's not OK. Here's why: there's a hose that runs from the intake piping.....
Sorry to cut that wonderful explanation short, but does that have anything to do with the temperature sensor(I believe) that was attached to the snorkel(3.0)? Currently, mine's is not located in the flow of intake air as it used to be since I removed my snorkel.
Old Oct 3, 2006 | 05:57 AM
GBAUER's Avatar
nope. The temp sensor is integral to the MAF on the 5.5 gens.
Old Oct 3, 2006 | 06:34 AM
TDotMax's Avatar
OH Rats@#$#@. That explains a lot. Fixing mine this weekend. I had a huge feeling. I hope this resolves my knock sensor codes. MY rear O2 is already dead.
Old Oct 3, 2006 | 06:39 AM
GBAUER's Avatar
replace the line and reset your ECU and it should be fine on the first issue. it may or may not resolve the knock sensor codes.
MaxStock
Dec 5, 2016 05:19 PM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
bumpypickle
Sep 20, 2015 08:22 AM
