speed sensor wire
Old Oct 4, 2006 | 02:33 PM
maxspeed96CT's Avatar
The original VQ...
speed sensor wire
I need help locating the speed sensor wire, wether next to the ecu or behind the tach, which ever.
I am hooking up a pioneer double din navi and i need to tap into the speed sensor wire.
Old Oct 4, 2006 | 04:49 PM
5thgenmaxima's Avatar
Maybe someone else will look it up or knows where it runs. Comes from the tranny. Not sure why a speed sensor would need to go to a deck anyways... Here is a pic behind the dash. pin # 17 or 62 goes to the gauge, assumably from the speed sensor... Tap into those 2 wires with an ohmmeter and see which one changes resistance in relation to speed change.
Old Oct 4, 2006 | 05:26 PM
The original VQ...
cool thanks man, the navi has to hook up to the speed sensor to get a more accurate idea of exactly how fast the car is traveling and the direction and etc...
Old Oct 4, 2006 | 05:31 PM
GBAUER's Avatar
but... it's navi. Shouldn't it already know that? Seems a little dumb to me. In fact, when I got new rims and tires I used the navi on my phone to make sure the OD was still the same as the OEM set-up by compairing my speedo to the navi speed.
Old Oct 5, 2006 | 10:47 AM
Old Oct 5, 2006 | 12:01 PM
misiek's Avatar
i have the avic-d2 and didnt hook up the speed sensor wire...
its used for the 3 gauge display when u dont wanna look at the map
other than that its really accurate without it
Old Oct 5, 2006 | 02:12 PM
The original VQ...
so does anyone know which wire it is for sure?
if worst comes to worst i wont hook it it, like i said it DOESNT NEED IT , it just says it makes it hlep the navi be more accurate and etc...
Old Oct 5, 2006 | 02:14 PM
The original VQ...
exactly, that means your navi IS hooked uop to your speed sensor........
Old Oct 5, 2006 | 04:22 PM
djfrestyl's Avatar
Suspension Yoda
Wow....
pink with blue stripe behind the instrument cluster. On the brown plug. Good luck.
(you would have gotten better luck in the audio section)
Old Oct 5, 2006 | 05:11 PM
The original VQ...
thanks, ya after i posted it i was like damm this is kindoff more audio related
Old Oct 6, 2006 | 09:15 PM
gadgeeets's Avatar
to help out more its the brown plug in the middle of the 3
Old Oct 7, 2006 | 02:17 PM
The original VQ...
hooked up the navi but didnt hok up the speedsensor wire, everything seems to work ok,
im still gona do the speed sensor wire , the install took me longer than it should of and it got dark and etc...
Guess the wire realy isnt nessecary
http://forums.maxima.org/showthread....82#post5288882
Old Oct 10, 2006 | 09:24 AM
gadgeeets's Avatar
i just did the same hook up...the gxe dash kit would look alot better. also hooking up the speed sensor wire will help out with the location of the vehicle,less errors as far as location of vehicle....did u do the mod ?
The Frye
Sep 2, 2021 11:03 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
sdotcarter
Sep 2, 2015 09:53 PM
