Resistor Removal
Resistor Removal
I am currently installing an Injen WAI (as Irish so kindly put it
) on a 2001 Maxima, and just took out my intake...
Im at the throttle body now and just wanted to know if there was a restrictor that is removable in or around the throttle body....I read somewhere on max.org that there is a Restrictor plate that is removable, but I can no longer find the thread
Thanks for your quick reply,
Justin
) on a 2001 Maxima, and just took out my intake...Im at the throttle body now and just wanted to know if there was a restrictor that is removable in or around the throttle body....I read somewhere on max.org that there is a Restrictor plate that is removable, but I can no longer find the thread
Justin
Originally Posted by P. Samson
NO there isn't. Unless you know what you are doing don't disturb anything on the throttle body.
I know what im doing, thank you very much...
just cause someone has __ post DOESNT auotmatically make them "noobs" when it comes to working on cars....
I dont care how many goofy questions you get all day...
Originally Posted by Nineleven
Anyways,
Can anyone help in answering my original question,
thank you
thank you
Long answer... No.
If your talking about the internal IAT sensor, when you put a 5th gen MAF sensor into a 5.5 gen that needs swapped into the new 5th gen MAF.
Anyways,
thank you
thank you
here is the full thread on this: http://forums.maxima.org/showthread.php?t=311146
Originally Posted by super6
YES there is. it is the TB restrictor plate, its between the TB and manifold. if u take off the 4 scews that hold the TB to manifold ull see a thin black plate that partly goes inside of the manifold, i removed mine will no bad effects. u can see it obstructs air flow by maybe a mm, honestly there is no difference, but looks somewhat piontless.
Hey thanks man
I always knew I wasnt crazy
Several people have removed the plate inside the TB - nobody has seen any gains from it. Most say it didn't really change anything. A few people had power loss.
My vote: don't mess with it. Nissan put it there for a reason, and it wasn't to "restrict" power......
iirc there is a 3-5mm difference between the manifold opening and the the size of this plate. i removed mine and did not notice a gain or loss. i did however put 197 in my N/A 2k1 auto with a fuel pump that would not hold pressure past 6k so the plate being removed was certainly not hurting anything.
and yes nissan probably could have spared the expense on this one
my03maxima
Jul 28, 2024 07:40 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
