Heater Core Flush, Please I Need Help
Old Oct 13, 2006 | 12:05 PM
AceofSpds's Avatar
wat
Ok i was ondering how to go about back flushing it, the haynes manual says for me to backflush it. Which hose do i put the garden hose through? The upper or the lower one?
Oh yeah any other input is appreciated on how to fix my heater. I have the regular climate control (not automatic) and when i turn the heat thing all the way over it just blows air no heat. I did what the haynes says about checking the hoses and they were both warm. So the next step is to backflush it and i dunno what they mean by back flushing. Any help is appreciated.
Im also guessing it would be wise to flush the hoses first then the core just in case there is a clog somewhere in one of the hoses.
Old Oct 13, 2006 | 12:34 PM
VaporHead
Just disconnect both of those hoses going to the heater core (engine side), stick a water hose in it (line) and flush. So the hoses will be connected to the core still, just not going to the radiator side. Have a bucket ready to catch the fluid that is in the line prior to disconnecting.
Old Oct 13, 2006 | 01:35 PM
AceofSpds's Avatar
wat
Ok so it doesnt matter wich direction i get the water to flow?
Im guessing the hose that goes into the block is the line that pushes the water into the core.
Thx for replying
Old Oct 13, 2006 | 03:14 PM
VaporHead
No, it shouldn't matter at all. Good luck!
Old Oct 13, 2006 | 03:26 PM
AceofSpds's Avatar
wat
I just got done flushing it out and heat still doesnt work
Old Oct 13, 2006 | 03:37 PM
5thgenmaxima's Avatar
What have you dont so far?
Is the switch operating correctly?
Is your engine overheating, etc?
Old Oct 13, 2006 | 03:38 PM
AceofSpds's Avatar
wat
Engine isnt overheating, what do you mean switch?
Ive been outside reading the haynes manual and talking on the phone to friends who might be able to help me and im just fearing im gonna have to change the core
Old Oct 13, 2006 | 03:50 PM
zagzig's Avatar
So if both tubes going the the heater core are hot once the car is warmed up and the fan is working correctly (you can feel air being blown out) then the temp acjustment flap must not be swinging open. I'm not exactly sure how the Maxi a set up, but your temp lever on you climate control adjusts a flap to regulate how mauch air comes from the heater core chamber or just from the outside. That flap must not be working for some reason.
Old Oct 13, 2006 | 03:53 PM
AceofSpds's Avatar
wat
Ok yeah thats what my friend on the phone was telling me about a vaulve or a flap, does anyone know the specific name of this flap? And yes my car does everything zagzig says
Old Oct 13, 2006 | 05:48 PM
VaporHead
Heater core is not going bad if you don't have an antifreeze leak and you are not overheating. It has to be that valve, which are usually a pain in the **** to fix and replace.
Old Oct 14, 2006 | 07:45 AM
PAREDLINE's Avatar
it's called the Air mix door and Air mix door motor which activates it.
Old Oct 14, 2006 | 08:37 AM
AceofSpds's Avatar
wat
thx a bunch man
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 18, 2015 07:07 PM
