shift light...
Old Oct 14, 2006 | 08:26 PM
Chaka's Avatar
Zulu
shift light...
i'm looking for a shift light...any idea about a good one?
Old Oct 14, 2006 | 08:31 PM
BUSi87's Avatar
I know that if you ask technosquare can make your check in light into a shift light.
Other then that check out autometer guages... they offer the best most accurate shift lights that i know of.
Old Oct 15, 2006 | 09:11 AM
Chaka's Avatar
Zulu
how do i contact technosquare?
Old Oct 15, 2006 | 11:10 AM
VaporHead
/http://www.technosquareinc.com/
Old Oct 20, 2006 | 02:21 PM
sanjeeve's Avatar
this is a little off topic - but when is a good time to shift? (ie at what RPM)
Old Oct 20, 2006 | 03:50 PM
irish44j's Avatar
retired moderator
before you hit redline....
Old Oct 20, 2006 | 04:24 PM
SoonerFan's Avatar
Cletus
i never understood why people need a shift light...if you know your car, you can hear exactly when to shift (right as you kiss redline)
Old Oct 20, 2006 | 05:07 PM
maxspeed96CT's Avatar
The original VQ...
actualy redline is at 6500, but you can bring it up to just before 6700.
Old Oct 20, 2006 | 05:14 PM
irish44j's Avatar
retired moderator
he asked what a GOOD time to shift was, not what the maximum rpms that he could shift at was....
It's a good idea to shift before redline.
Old Oct 20, 2006 | 05:16 PM
AceofSpds's Avatar
wat
Hehe how do u guys know hes not asking when 2 shift for good gas milage? JP
Consistancy for bracket racing? Thats the only real excuse i could think of...
Old Oct 20, 2006 | 05:18 PM
The original VQ...
well i figured he ment as he was racing, 1st and 2nd gear are best squeezed out all the way....
A good time to shift is 3k tho, save gas but you dnt bog
Old Oct 21, 2006 | 08:26 AM
sanjeeve's Avatar
well I guess I should have explained my situation a little more...
I just bought my car about a month ago and It's my first manual...From what I understand - idealy you want to keep your engine in it's "optimum power band" while keeping fuel consumption to a reasonable level...
I guess there isn't really one answer to the question, but I guess I just want to get an idea of what the "average" shifting point is...
I hope that makes sense!
Old Oct 21, 2006 | 08:34 AM
LA02MAX's Avatar
Well I would post a graph posted here:
http://forums.maxima.org/showpost.ph...23&postcount=5
but it seems the pictures are down, so just read the text
Old Oct 22, 2006 | 10:24 AM
chr0nos's Avatar
1st to 2nd is usually a little higher than the rest to get a smoother shift.
the rest should be around 3k rpm for best gas milage. just dont sit there and wait between shifts. my buddy does that and his rpms drop, then he shifts into next gear. you get unnessessary clutch wear that way, plus the car jerks when the clutch engages. not smooth driving at all.
Old Oct 22, 2006 | 11:11 AM
Chaka's Avatar
Zulu
i don't have any aftermarket exhaust...and i would say the max engine is quite quiet...with windows down, it's really hard to tell without looking....
Old Oct 23, 2006 | 05:27 AM
SoonerFan's Avatar
Cletus
i dont have aftermarket exhaust either
Old Oct 23, 2006 | 05:46 AM
xlcrew's Avatar
I’m Back
i have one, and the reason being is because i have nitrous, and i just wanted some help because sometimes the tach can't keep up with the motor and that's when a shift light helps. i got mine from summit for like 40 bucks and i have it mounted behind the center air vents so you can't see it unless it's lit up.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
