stalls; clogged precat in y-pipe? fed or cali spec?
Old Oct 17, 2006 | 06:45 PM
getbigtony's Avatar
stalls; clogged precat in y-pipe? fed or cali spec? p0430?
hey guys, i just hit 92000mi on my car and it started to stall two days ago when at idle. even when i'm driving and depress the clutch, it'll just go. this only happens after the car is warmed up though, that's why it makes me believe it's the precat or cat. i don't think it's the ignition coils either cuz it's fine at start up, and i have no misfires. i've had a p0430 code for a while, when i had a leak on the intake from the scoop not staying connected, and i got a cheapo intake from fleabay and the SES light was intermittent. now i think the precat's done for and clogging up, causing too much back pressure. it's not the MAF cuz it runs fine all the way up to 6.5k RPM; i've tried to disconnect it and it's still the same.
anyone had the same problems?
would anyone know if i have cali spec or fed spec when i have o2 sensors in the y pipe and exhaust manifolds? none are before or after the main cat in the center.
also, think i should go with aftermarket ypipe? how's them budget stainless steel ones? i've read that they provide some of the best prices
tia,
tony
Old Oct 17, 2006 | 07:11 PM
NmexMAX's Avatar
dot dot dot ...
How many o2 sensors do you have? 3 or 4?
3 = Fed
4 = Cali
Old Oct 17, 2006 | 08:13 PM
getbigtony's Avatar
i believe i have one on each of the exhuast manifolds, and one of each end of the y pipe, unless i was mistaken, for a total of 4
Old Oct 17, 2006 | 08:17 PM
NmexMAX's Avatar
dot dot dot ...
What MIL code does your SES light refer to?
Old Oct 17, 2006 | 09:59 PM
getbigtony's Avatar
well the p430 was: Catalyst System Efficiency Below Threshold (Bank 2)
Old Oct 17, 2006 | 11:08 PM
getbigtony's Avatar
after some research, can anyone confirm p0430 is for main cat and no precat? from what i've read, that might be it
Old Oct 18, 2006 | 06:19 AM
frankd121's Avatar
http://forums.maxima.org/showthread.php?t=289375
Even though its for P0420, its pretty much the same problem except it refers to bank 1. Hope this helps.
Old Oct 18, 2006 | 04:40 PM
getbigtony's Avatar
thanks for the help; will look into that
Old Oct 18, 2006 | 10:00 PM
getbigtony's Avatar
anyone know how to clean the IAC motor/valve? where is it located? right behind the throttle body?
Old Oct 20, 2006 | 05:27 PM
getbigtony's Avatar
ok anyone know FOR SURE FIRSTHAND, if p0430 deals with main cat or pre cat? where's the precat located in cali spec? exhaust manifold or y pipe?
jmlee44
Oct 2, 2022 02:13 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
