tranny flush
Old Oct 19, 2006 | 05:44 PM
raymond3414's Avatar
tranny flush
I need my trans. drained and cleaned, but I want a pro to do it. If I take it to somewhere like AAMCO do you think that, they will do a good job, and could I use the ATF that I bring. I think Im gonna go with amsoil ATF. And should 6 bottles do?
Old Oct 19, 2006 | 06:34 PM
VaporHead
Never brought my car to AAMCo so I can't tell you anything about that. But, they will probably have to use there ATF because it's usually attached to the machine they use to flush it. I could be wrong.
Old Oct 20, 2006 | 09:30 AM
jvienneau's Avatar
It's more like 11 qts for a full flush. Amsoil is wasted money IMHO, but you didn't ask. :-)
Old Oct 20, 2006 | 09:42 AM
q45Owner's Avatar
Drain & Refill is different than Flush - hopefully you are clear on the differences.
AAMCO may not be doing the flushes - when I went to them couple years back they only did Pan drop, drain, and refill - this does not get all the fluid out of the system.
I would go to a trany Flush shop - the cost is generally in the $69-79 range. Some will allow you to bring in your own Fluid, Mobil-1 synthetic ATF works good - does cost serious moola ($6 a quart) - you will need some 10-12 quarts to really flush the tranny.
Old Oct 20, 2006 | 09:46 AM
rmd0311's Avatar
I would go to the sTEALERship... Check for their specials, they sometimes have great offers. Even when they don't, its like $129. At least that's what it was for my wife's Sienna at the Toyo dealer. This is not something I would trust an Oil and Lube place with, this is something that should be done either by yourself (not a full drain) or by someone YOU TRUST.
Old Oct 20, 2006 | 09:50 AM
n3985's Avatar
大陆弟弟
Please explain
Old Oct 20, 2006 | 10:15 AM
pbn85's Avatar
stick with amsoil...thats all I use and I strongly recommend their products
user 11122324
42
Jul 18, 2022 03:35 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
RWCreative
Sep 21, 2015 11:01 AM
pktaske
Sep 4, 2015 08:40 AM
