RPM at 80MPH
Old Oct 23, 2006 | 06:16 PM
rmd0311's Avatar
RPM at 80MPH
Hey Guys I'm sure this has been asked before. I just did a search and browsed through the first 5 pages and found nothing so I figure I'd just ask.
I have an 01 5Spd. When in the highway my RPM at 80 are like 3400RPM . Is this what everyone else gets? I find it a bit high and just want to make sure I am not alone. I figure a V6 with 222HP would have a lower RPM at 80 which is what I usually cruise at.
What's your RPM at 80? 5th gen people please... I know the 5.55Gen is under 3000 at 80, I actually found a thread on that one. Not the 5th gen though.
Please chime in... thanks.
Old Oct 23, 2006 | 06:36 PM
vinny's Avatar
that about what i got
Old Oct 23, 2006 | 06:37 PM
MacGarnicle's Avatar
at 80 I'm around 2700? 3400 does seem very high..
Old Oct 23, 2006 | 06:38 PM
NmexMAX's Avatar
dot dot dot ...
It's a mechanical relation, and is tied into your tranny,speedometer,
So it will always be the same as everyone else
Old Oct 23, 2006 | 06:46 PM
00Max00's Avatar
2750rpm@80mph, auto
Old Oct 23, 2006 | 06:48 PM
alicious's Avatar
the org...not what it was
mine is around 2900rpm, & I have an auto, i think yours might be a little high...
Old Oct 23, 2006 | 06:51 PM
NmexMAX's Avatar
dot dot dot ...
So anyone care to explain why it would be 'high'? Slipping clutch?
Originally Posted by 00Max00
2750rpm@80mph, auto
Post not valid.
Originally Posted by rmd0311
I have an 01 5Spd
LA02MAX's Avatar
slipping clutch? haha, i'm at 2500 here....6-speed FTW!
Old Oct 23, 2006 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
I like how they say it's high but no explanation as to why
I've seen your RPM/Speedometer pic 6spd FTW.
I finally got ~ 250 miles per 1/2 tank. Another 'funny' and invalid comparison.
LW wheels FTW. 27MPG IBanothermpgthread
Old Oct 23, 2006 | 07:44 PM
rmd0311's Avatar
Anyone with a 5spd 5th Gen care to chime in... Would an Auto be any diff than my 5spd?
Old Oct 23, 2006 | 07:46 PM
NmexMAX's Avatar
dot dot dot ...
It most definately would. Reason being is the gear ratios are different.
Old Oct 23, 2006 | 07:49 PM
LA02MAX's Avatar
and typically 5spd manuals are turning slower than 4ATs at highway speeds...
Old Oct 23, 2006 | 08:00 PM
rmd0311's Avatar
Ok., so I just did a more detailed search dating back to 2000. A lot RPM threads for 2002-03 but very few for the 00-01.
FYI - My idle is at 600-650RPM... I will also, check my RPM at other speeds tomorrow morning during my commute. Hope some more chime in. Thanks
Old Oct 23, 2006 | 08:14 PM
NmexMAX's Avatar
dot dot dot ...
Read this, http://forums.maxima.org/showpost.ph...22&postcount=3
Plug in your info. http://forums.maxima.org/showthread....os#post4102259
Do some algebra. Get your answer.
Old Oct 23, 2006 | 08:27 PM
AnDyMaN's Avatar
mine is around 3300. i have a 5 speed. and as far as i can tell its normal. its not the most fuel efficient 5th gear, but it pulls pretty hard.
Old Oct 23, 2006 | 08:30 PM
Hoooper
from what ive found thats not true. most 5spds tend to turn pretty high RPM's on the highway.
Old Oct 23, 2006 | 08:42 PM
96blkonblkse's Avatar
seeing as the 4th gen 5spd and 5th gen 5spd are virtually identical, my 4th gen at 80MPH(130KMH) is around that too.
Old Oct 23, 2006 | 09:16 PM
Maxfli's Avatar
I know this is a 5th gen question but on my 5.5 with no cars around, I did a quick run to 100...3200RPM in 6th!
Old Oct 23, 2006 | 09:43 PM
Ride2kMax's Avatar
i got a 2k and does 80 in about the same 3300/3400 rpm.
Its normal dont worry about i used to have the same question.
Old Oct 23, 2006 | 11:07 PM
asianstyle's Avatar
hey man I've got a 2001 5sp, about 28, 2900 for me at 80mph
Old Oct 23, 2006 | 11:44 PM
Hoooper
this will also depend on tire/wheel combo. not too much but a little
Old Oct 24, 2006 | 03:23 AM
Curt's Avatar
I don't believe that's correct: the VSS reads the tire-RPM's from the transmission differential and sends that as an electrical signal, I believe to the speedometer. Whether you're running 22" diameter front tires or 30" ones (which will most definitely yield vastly different actual speeds at identical wheel RPM's), at any given wheel-RPM the speedo is getting the same signal from the VSS (regardless of the tire diameter) and converts it to MPH based upon the stock tire circumference it's been programmed to believe you're running. Now if a cop is reading your speed on a radar gun and you're running smaller-than-stock tires (i.e., shorter), then your engine RPM for an actual speed will run higher than with stock-size tires.
Doesn't answer the original question of why the RPM's seem unusually high for an indicated 80MPH. My 4th gen with a 5th gen 5-speed with VLSD runs around 3100-3200 RPM at 80 MPH.
Old Oct 24, 2006 | 06:00 AM
Y2KMaxGXE-R's Avatar
5 spd at 80 rpm should be at 3250-3300.
VQ30 automatic, VQ35 manual, VQ35 automatic will have different RPMs because of different gear ratios.
rmd0311: 3700 is a lot of rpm's for 80 mph. What tire/wheel combo are you running, how many miles on your car? Did you test on a straight and even roadt stretch over a couple of miles? It may seem like your clutch is starting to go....
Old Oct 24, 2006 | 06:05 AM
NmexMAX's Avatar
dot dot dot ...
Cliffs,
In the real world yes, but not on the dash.
Old Oct 24, 2006 | 07:29 AM
rmd0311's Avatar
I'm actually at like 3300/3400 at 80.
Old Oct 24, 2006 | 07:50 AM
rmd0311's Avatar
:sorry: Double post...
Old Oct 24, 2006 | 08:41 AM
zheka's Avatar
dang that sucks, i wreaked my 2000 auto max a couple months ago, and now i have a 2k manuel in the collision shop geting fixed. you say it has around 33-34 rpms at 80???? what is your MPG on the highway? the rpms are like a civic!
Old Oct 24, 2006 | 08:44 AM
rmd0311's Avatar
I did an all highway trip not too long ago and I got like 25mpg...
Old Oct 24, 2006 | 08:54 AM
maxmumsxspd's Avatar
2400ish in 6th at 80mph with my 6 speed... but 3400 seems about right for a 5speed...my friends 5speed prelude has similar RPMs at the speed. dont think u have anything to worry about
Old Oct 24, 2006 | 10:02 AM
TeamZ33's Avatar
I always wondered about this too. Good to hear that I'm not the only one around 3300rpm.
Old Oct 24, 2006 | 10:09 AM
my 2k GXE 5spd is getting 25-30 mpg in 5th gear, depending on the load, wind, weather, quality of gas....
Old Oct 24, 2006 | 10:18 AM
00Max00's Avatar
The prelude is a four banger
Old Oct 24, 2006 | 10:19 AM
00Max00's Avatar
...with 3300-3400 rpms at 80????
Old Oct 24, 2006 | 10:31 AM
LA02MAX's Avatar
Just to brag
and yes I did get 300 miles on a half tank...
Old Oct 24, 2006 | 10:32 AM
rmd0311's Avatar
I knew I started this thread for a reason...
Old Oct 24, 2006 | 10:47 AM
C P Squared's Avatar
Is your car an auto or a manual, and also did you have overdrive off, when ever i turn mine off the rpm's seem to go higher
Old Oct 24, 2006 | 11:10 AM
rlsport87's Avatar
01 Maxi....~3000 @ 80mph
rmd0311's Avatar
Just to brag
How the hell did you get 300 miles to a half tank? Was your car on crack at the time? Long trip, granny driving. Or better yet, did the needle suddenly frop from half tank to empty 70 miles later.
Old Oct 24, 2006 | 11:14 AM
LA02MAX's Avatar
How the hell did you get 300 miles to a half tank? Was your car on crack at the time? Long trip, granny driving. Or better yet, did the needle suddenly from half tank to empty 70 miles later.
Nope, I got about 570 miles out of a little over 17 gallons....it was on a long trip and I had my sunroof open with the a/c off. I've seen similar results several times even with the A/C on. I used to get 28-29 mpg every time I filled up mixed city/hwy driving, and now I only get 22 mpg because I live in a city with a crapload of traffic and all my driving consists of trips < 3mi...it sucks...
Old Oct 24, 2006 | 11:35 AM
Now is your car a 4 cyl, or a 6cyl?
Mines a V6 and it doesnt get nearly that many miles per gallon highway
