Spark problem
Old Oct 24, 2006 | 03:43 PM
Hoooper
Spark problem
ok, i have a pretty pressing and serious problem. did a 6spd swap and car will not start. it will crank fine, but will only spark once. when the engine is initially turned over, it will spark once then will no longer spark.
Parts used:
6spd tranny
6spd ECU
6spd wiring harness
shifter, clutch and all that
Problems checked and are ok:
ground above CPS
all immobilizer parts (including key)
Neutral safety switch and clutch safety switch
Old Oct 24, 2006 | 04:46 PM
Hoooper
Please?!?!?!?!
Old Oct 24, 2006 | 05:04 PM
PRoosen's Avatar
That is a new one. Sounds like there is good spark from the starter, but may be a wiring problem since once it turns over there is no spark. I am not sure where to start though. I would go over the wiring again...
Old Oct 24, 2006 | 07:40 PM
Hoooper
yeah its weird. any help appreciated
Old Oct 24, 2006 | 08:03 PM
MIKE2K2's Avatar
Custom User Title
You gotta push the clutch in.
Old Oct 24, 2006 | 08:48 PM
Hoooper
thats taken care of, dont worry
Old Oct 24, 2006 | 09:08 PM
NewLoveI30's Avatar
May be totally wrong, but do you need to get your key reprogramed with the new ECU???
I would doubt it would even turn over if the immobilizer was active, but thats all I can think of.
Old Oct 24, 2006 | 09:18 PM
Hoooper
yeah, the immo is ok too, been reprogrammed
Old Oct 25, 2006 | 11:46 AM
Hoooper
help still needed
Old Oct 25, 2006 | 02:10 PM
mist max2000's Avatar
tough one,.. gotta be something with the wiring i wouldnt know where to begin though besides going over it all again... hopefully someone will know?? G/l
Old Oct 25, 2006 | 03:41 PM
madmax20019's Avatar
Its electrical
Check the switches-nuetral safety switch.
Old Oct 25, 2006 | 04:34 PM
Hoooper
i guess ill ask him to check again, any suggestions still very welcome though
Old Oct 25, 2006 | 06:07 PM
ZIPPIN's Avatar
Mauja He Mauja
PM BlackBIRDVQ..I am sure he will be able to help
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
JoshG
51
Sep 21, 2015 10:41 PM
