Need to know if 2003 350z 18" rims will fit on my 00 max. Will 8.5'' fit the rear?
Old Nov 2, 2006 | 05:53 AM
scheibler's Avatar
First off, I don't really know much about rims and was wondering if 2003 350z rims wold fit my max since I have seen g35 rims on som max's. One of my friends buddy's is selling his stock 18" 2003 350z rims to get aftermarket. I have the stock 16" stealies on my 2000 max now, but would like to get these if they will fit. I believe these are the size of the rims:
18x7.5 front
18x8.0 rear
They may be 18x8.0 front and 18x8.5 rear though. I know they are the same bolt pattern as the max, but don't know if the offset is the same. Will these fit on my max without tire rub or the wheels sticking out from the car? I need to know soon because he is waiting on my decision.
Old Nov 2, 2006 | 06:15 AM
burnurass's Avatar
it should fit but it depends on your drop/tires on the wheel.
ALSO..I think you'll get better responses in the wheel/tire section...
Old Nov 2, 2006 | 08:20 AM
scheibler's Avatar
I posted in both b/c I need a quick response. I have the stock suspension/drop and will be getting new tires on the wheels. My main concern is the width of the back tire. Will I need spacers to even the font and back wheels?
Old Nov 2, 2006 | 08:44 AM
SoonerFan's Avatar
Cletus
the width will be fine. i have the Z 17s for auto-x (17 X 7.5 and 17 X 8) and they are fine. i actually put the wider ones up front.
Old Nov 2, 2006 | 09:16 AM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
.... i have the g35 rims on mine... the 18s from the coupe... on the inside of the rim it said front or rear... and my rear pass side does rub only on dips... and i have illuminas with h&rs all around...
another thing is would u mind if i asked a question since there is an open thread... didn't wanna jack up ur thread without sayin anything about ur situation
Old Nov 2, 2006 | 10:08 AM
scheibler's Avatar
ask a question
Old Nov 2, 2006 | 11:54 AM
KabirUTA13's Avatar
wondering if a set of rims 18 x 9.5... 4 of em... will fit on the max... i have no idea wat the offset is
Old Nov 2, 2006 | 12:36 PM
NewLoveI30's Avatar
i have no experience with tires that wide, but I imagine you would get quite a lot of rubbing with 9.5". And it would really kill your turning radius... Which is not great to begin with.
Old Nov 2, 2006 | 01:19 PM
Darius's Avatar
are you talking about these wheels? (see sig) they're 18x8 all around. I'm running 235/40/18 on all 4, with k-sport coilover drop and no rubbing issues and no spacers
Old Nov 2, 2006 | 05:20 PM
scheibler's Avatar
will these size tires fit on the max with the 350z rims?
front- 235/40/R18
rear- 245/45/R18
Old Nov 2, 2006 | 05:26 PM
Darius's Avatar
Why would you want bigger tires on the rear? maximas are FWD..
Old Nov 2, 2006 | 05:36 PM
scheibler's Avatar
b/c I can get a set of 2003 350z 18" rims with Falken tires for $400. That is the tires already on the wheels which I believe are 18x8 front and 18x8.5 rear
Old Nov 2, 2006 | 05:43 PM
ope2k4's Avatar
It depends on the offset. I have 18X9 all around and it doesn't rub.
Whats the offset?
Old Nov 2, 2006 | 08:25 PM
Maxfli's Avatar
If your buddy has the "Performance" version of the Z, they are 18x7.5 front and 18x8 in back. If he has the "Track" version, they are 18x8 front and 18x8.5 in back.
http://www.nissannews.com/site_libra...0z/specs.shtml
If you have seen the wheels, you can look here and figure out which ones they are and the offset:
http://www.350z-tech.com/zwiki/Wheel...rack_18.22_v.1
Either way, it looks like they should fit.
Old Nov 3, 2006 | 08:19 AM
scheibler's Avatar
the only problem is the tire size. I have heard that the rear tires...the size i listed in a post above may be too tall
Old Nov 3, 2006 | 09:04 AM
mist max2000's Avatar
400 dollars,.. your crazy if you dont buy that,.. if they dont fit u can throw that on ebay and get at least double that (if the tires dont have alot of wear)
stevesmax
Dec 17, 2020 11:57 AM
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
twotonezed
Aug 16, 2015 11:41 AM
