Yes LED bulbs for our Gauges.
Old Jul 25, 2007 | 06:41 PM
  #161
imported_eddie_D's Avatar
Nice thread.
Ordering bulbs tomorrow. And awaiting that write up.
Old Jul 25, 2007 | 07:39 PM
  #162
GigEmAgs07's Avatar
myownnismo... have you taken the night pics yet? you little tease
Old Jul 26, 2007 | 03:00 AM
  #163
MyownNismo's Avatar
Future Camaro SS owner
BEFORE
AFTER
I have the write-up up today. Just getting the pics in the right spot according to steps.
Old Jul 28, 2007 | 11:14 AM
  #164
Can I see the write up please?
Old Jul 28, 2007 | 04:13 PM
  #165
MyownNismo's Avatar
I am missing a couple pics but if you don't see what I am talking about in the write-up I can pull my gauges out and take some pics.
WRITE-UP
http://www.cardomain.com/ride/180317/5
Old Jul 28, 2007 | 05:52 PM
  #166
Dan5.5's Avatar
Do you want to offer a service for doing this.
Like people send you thier crap and do this mod and send it back
Just an idea, i would be intrested.
Old Jul 28, 2007 | 07:40 PM
  #167
MyownNismo's Avatar
I could cut down the bulbs but you would still have to install them and trim off the 1/8th of the tab that's on the gauge itself. That I just used the cutter on a pair pliers. Unless you have another car and can send your whole cluster.
Old Jul 28, 2007 | 09:46 PM
  #168
Dan5.5's Avatar
How much would you charge for me if i send you the whole cluster.
Old Jul 29, 2007 | 01:54 PM
  #169
MyownNismo's Avatar
Since it's easy for me to do as long as you pay for the shipping back to you it would be all good. Plus then I can take more detailed pics for the write-up.
Old Jul 29, 2007 | 03:44 PM
  #170
soundmike's Avatar
Very sound, Mike
WRITE-UP
Very nice.
Is it an issue taking the needles off? Would it need to be recalibrated? I have a spare 2k2 cluster here but i could not figure out after tinkering with it if the needles had some type of notch to make sure it goes back where it should. (I never attached it to the car so i haven't gone that far with it).
Old Jul 29, 2007 | 04:46 PM
  #171
MyownNismo's Avatar
Originally Posted by soundmike
Very nice.
You don't have to take the needles off. With unscrewing the four silver screws on the back the whole speedo and tach come out. You only have to take needles off if you want to strip the blue film off the gauges which I didn't do. If Dan5.5 sends me his cluster I will take more detailed pics of the process.
Old Jul 29, 2007 | 06:49 PM
  #172
soundmike's Avatar
Very sound, Mike
I should've mentioned earlier, i have a 5.5 gen. The cluster is built differently. Here are a couple of photos of the front and back. It's the most dissassembly i can do without touching the needles.
Here's how it looks behind the face (and needles taken out)
Old Jul 29, 2007 | 07:38 PM
  #173
pyroz's Avatar
lol, good luck with the needle recalibration, i did that with my civic back then, and it was a ***** to recalibrate it. so i just sucked it up and the speedo was 3-4 miles off.
Old Jul 29, 2007 | 08:03 PM
  #174
pyroz's Avatar
also, what # bulbs are for the manual climate control for a 2k maxima se? i want to replacemine because the bulbs gave out.
Old Jul 30, 2007 | 02:06 PM
  #175
MyownNismo's Avatar
Wow that's way different from mine. I really don't think this would work for 02-03 owners.
Old Jul 30, 2007 | 10:29 PM
  #176
Dan5.5's Avatar
Damn it !!!!
Old Jul 31, 2007 | 02:21 PM
  #177
MyownNismo's Avatar
How much room is behind the gauge face and the white part. Maybe you could fit a cold cathode ring behind it. But that would require the calibration of the needles.
Old Jul 31, 2007 | 03:56 PM
  #178
rmaxima02's Avatar
They don't look much different from the original color. The white ones are much better.
Old Jul 31, 2007 | 04:16 PM
  #179
soundmike's Avatar
Very sound, Mike
Not a lot since that space is occupied by clear plastic with variable fine notches which i figure is there to help distribute the light evenly (together with the variable opaqueness of the face itself).
I did try a flex LED wire but the one i got was too small--so back to the drawing board on that one. A CCFL ring might actually work better now that you mention it.
The other option i'm looking into are EL sheets that you can cut yourself, the only problem there is although the light emitted will be uniform, the pattern on the face will block certain areas more than others, effectively making the output uneven once installed.
Old Aug 2, 2007 | 08:00 PM
  #180
Thanks for the write up greatly appreciated.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
