iintrument cluster compatibility question
Old Nov 4, 2006 | 07:41 PM
NYghettoGLE's Avatar
ok, here goes my problem.
i have a 2000 GLE auto with TCS. Very early production model, i believe 4/99.
i had my instrument cluster modified by adding polarg white bulbs, very bright and nice indeed.
however in the process ALL the needles got FUXXED.
Gas shows more.
Speed shows less.
Tach shows more.
Temp is always sky high all the way up.
so i decided to shop for a SE cluster with TCS (nearly impossible to find). i want a SE cluster because the white faces look a lot better than the all black GLE.
as far as i'm concerned, both 2000 and 2001 instrument clusters are backward compatible.
anyways, i got a 2001 SE with TCS. (maybe it's a AE, seller was not 100% sure).
i got 3 problems:
1) now, every needle works PERFECTLY exept the Temp. Temp is totally dead, it doesn't move at all.
2) TCS does not work (when i push button to disengage, it doesn't ligght up).
3) ABS light stays on indefinitelly.
can anyone PLEASE help me?
Old Nov 4, 2006 | 11:00 PM
ktranne's Avatar
NOOB
did you disconnect the battery when doing the swap?
I read that on TT.net that if you dont disconnect, abs will come on.
Unclejunebug
Apr 2, 2016 05:42 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Socalstillen
Sep 26, 2015 12:01 PM
