Disabling Daytime Running Light Feature
Old Nov 5, 2006 | 07:09 PM
M1RAG3's Avatar
Just like the tread says I'm trying to find a way to disable my daytime running lights....is this even possible with a 5th gen Maxima?.....if anyone has experience with this please shed some light on this issue
Old Nov 5, 2006 | 07:11 PM
VaporHead
There should be a relay for these in the engine bay. Also, aren't they required up there in Canada?
Old Nov 5, 2006 | 07:14 PM
M1RAG3's Avatar
I would assume that they are but the Police here are pretty lax......the reason I want to disable this feature is so that there wont be ANY power flowing through the harness unless I have the selector turned past the first notch....normally there is still flow even if you dont touch the selector and this is the DRL feature
Old Nov 6, 2006 | 06:35 AM
M1RAG3's Avatar
BUMP...anybody or no?
Old Nov 6, 2006 | 08:20 AM
Teufelhunden's Avatar
hows the E-bay kit holdin up?? still in one piece?
Old Nov 6, 2006 | 09:19 AM
MacGarnicle's Avatar
Manufacturers are legislated to have DRL installed and I think the intention is that the lights are to be running at all times (safety) but the laws surrounding the matter are iffy, so I wouldn't expect any ticket if they're not on..
as to how to disable them.. not sure..
Old Nov 6, 2006 | 09:49 AM
00MaxSE's Avatar
Pointy Elbows
PM Progress. He has done it. I believe he just pulled a fuse out or something.
Old Nov 6, 2006 | 11:23 AM
M1RAG3's Avatar
Actually no...I returned my car to stock just so I could be as cool as you are ......................just kidding
Old Nov 6, 2006 | 02:03 PM
SoonerFan's Avatar
Cletus
there is a switch connected to the e-brake. if the e-brake is engaged, the lights go off. should be able to do something with that
Old Nov 6, 2006 | 04:30 PM
TDotMax's Avatar
Theres fuses in your engine bay. Our cars are very different from US cars with our DRL's. Or you can unplug the day harness from the day running control unit found beside the washer bottle.
But why would you want to take it out? It is law to have these, yes cops won't do crap about it however you get in an accident and you could get screwed as it is part of safety regulations. Key word though is Could!..In my old lude a few years back returning home from DarkNights I got nailed with a nice $300 ticket for not having it (fought it and got off but still a pain). If anything re-wire to your fogs if those are the OEM ones you still have in your sig.
Old Nov 6, 2006 | 07:01 PM
lalaMAX's Avatar
forget about the fuse thing.... it never worked... at lease for me...
but one thing u can do is blown one your your high beam, then DRL will disable by it self.... if u have a 5 gen then it's what i have, i think that's the only way.... i asked here long time ago but no one can get me an answer... DO NOT REMOVE the headlight fuse next to your batt, DRL will make 100% curren flow to the other side... but i am thinking the hand break thing... if somehow i can make that red handbreak light on all the time, then DRL will not even come on!
Old Nov 6, 2006 | 09:02 PM
Nathan's Avatar
How about installing 2 blown bulbs into them so they'll still be current going to them, but they wont turn on. Besides that, I'm out of ideas.
Old Nov 6, 2006 | 10:42 PM
M1RAG3's Avatar
I got the fix from member Progress, it is simply disabled by pulling out the "DTRL" fuse from the cabin's fusebox. I needed to disable this feature to ensure that my HIDs were not constantly "ON"...since the power for my kit comes directly from the OEM harness, with the DRL feature there was always current (even if minimal) flowing through the harness and thus constantly powering the HID kit. Now that this fuse is pulled, the HID kit doesnt power up until I turn the selector to the 2nd notch on the steering wheel mounted stick...since no current is flowing through the harness until the 2nd notch is reached......hope this can be helpful to someone else!
Old Nov 7, 2006 | 05:02 AM
TDotMax's Avatar
But since you have the projectors why not just run your days through the inner circle housing?
Old Nov 7, 2006 | 06:02 AM
M1RAG3's Avatar
Its a bit more complicated than it seems....anyone who has tried to wire an HID kit to these projector headlights will have experienced similar problems to me....the good part is now those problems are fixed
Old Jan 25, 2009 | 10:57 AM
Stereodude's Avatar
Sorry for bumping an old thread, but do the high beams and everything else still work normally after disabling the DRL's by removing the fuse? I ask because the wiring diagrams in the service manual show that the high beam relays are connected only to the Daytime Light Control Unit.
And before anyone jumps all over me, I have a Canadian purchased Maxima in the US.
Old Jan 25, 2009 | 11:12 AM
M1RAG3's Avatar
if thats what the circuit diagrams say then by disabling DRLs then I would assume you also disable your highbeams....you should just go to your in-cabin fusebox and pull out the DTRL fuse and then check to see if your highbeams work...its like a 1 minute job and you'll know the answer to your question.
Old Jan 25, 2009 | 11:18 AM
Progress's Avatar
It's business time.
Just remove the DTRL fuse. Your high beams will work with the fuse pulled; mine has for years.
Old Jan 26, 2009 | 04:42 PM
Stereodude's Avatar
Originally Posted by Progress
Just remove the DTRL fuse. Your high beams will work with the fuse pulled; man has for years.
What number is the fuse? There is no "DTRL" fuse in the cabin (at least per the diagram and markings on the back of the fuse panel cover).
From the service manual it looks like it might be #28 or #21, but the diagram on the fuse panel cover say #28 is "Air Cond" and #21 is "Start Signal". #21 seems to be also used for the clutch interlock, so I guess it's #28.
Old Jan 26, 2009 | 04:56 PM
Progress's Avatar
It's business time.
From the service manual it looks like it might be #28, but the diagram on the fuse panel cover say #28 is the air conditioning.
To be honest, I don't have my car right now so I can't check.
In my car, there is a fuse in the cabin that reads "DTRL." It might read "DRL." The only other fuses to check would be in the engine bay. Is your car from Canada?
Old Jan 26, 2009 | 04:58 PM
Stereodude's Avatar
It is. I bought it new in Toronto. I guess I will pull #28 and see what happens. The service manual doesn't link #28 to the A/C.
Old Jan 26, 2009 | 05:08 PM
Stereodude's Avatar
Ok, well #28 definitely turns off the DRL's. Unfortunately it also turns off the whole automatic climate control system, so that's out.
I guess I either need to see how the parking brake is connected to the Daytime Light Control Unit, or find the unit and cut the wire going to terminal 3.
Old Jan 26, 2009 | 06:02 PM
Progress's Avatar
It's business time.
That's strange. You do have a 2000 from Canada, like my car, right?
Old Jan 26, 2009 | 06:37 PM
Stereodude's Avatar
No, I have a 2002 SE from Canada.
I got them disabled now. I cut the green wire that goes to terminal 3 of the Daytime Light Control Unit.
Now I can move forward with my evil plan to HID my high beams.
tsi6001
Oct 3, 2022 10:23 PM
rtirbany
Sep 8, 2015 11:46 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
