P1126 error troubleshooting
Old Nov 11, 2006 | 05:49 PM
jettatdi's Avatar
Got a 2000 Max and been slowly fixing the CEL codes (have had a few so far) It has high miles (160k) and so far I have replaced the MAF and the front coils and it is running pretty smooth now (It was knocking like crazy at cold start-up). Now though I got this when I had it checked at Auto Zone:
P1126 "Throttle position (narrow range) sensor circuit malfunction"
I am wondering if I should replace the thermostat, front coils or the TPS?
Thanks,
Old Nov 12, 2006 | 06:28 PM
jettatdi's Avatar
Bump because I want to fix this soon! Thanks to anyone who can offer advice!
Old Nov 12, 2006 | 06:36 PM
NmexMAX's Avatar
dot dot dot ...
Why would you change the thermostat or coils when the problem is clearly the TPS?
Old Nov 12, 2006 | 07:22 PM
P. Samson's Avatar
P1126 is a thermostat function code. Set when the ECM does not see a correct rise in coolant temp. after start up. Could be a stuck open thermostat OR a coolant temp. sensor or circuit issue. After starting the engine does the coolant temp. gauge needle slowly go up to about half way on the gauge and have you got lots of heat from the heater? If that is normal, then it could be the coolant temp. sensor or circuit (the one for the ECM) and which is critical for the system operation.
Old Nov 12, 2006 | 11:43 PM
getbigtony's Avatar
what a crappy code if it is about coolant temp and what not.. would throw you completely off
keep us updated if you ever figure it out please
Old Nov 13, 2006 | 08:56 AM
jettatdi's Avatar
The temp gauge goes almost to halfway, but never more than that. I will start it cold and see how hot the heater gets, then go from there.
Old Nov 13, 2006 | 01:54 PM
jballa2KSE's Avatar
P1126 is the thermostat. I just got the code a little while ago, and replaced it myself, problem solved. You should notice that your temp guage will creep up very slowly to its normal range, this is because the thermostat is constantly trying to cool the motor down (stuck open) The throttle pos. sensor... is for 02 03. Hope that helps
Old Nov 13, 2006 | 07:49 PM
jettatdi's Avatar
Thanks Jballa. I'll replace it this week and let you know what happens.
Old Nov 21, 2006 | 09:29 AM
jettatdi's Avatar
OK replaced the thermostat and reset the CEL. Drove almost 100 miles now and so far so good. Think I need to just replace the rear coils and I will be set.
Thanks for the advice!
knight_yyz
Nov 6, 2015 02:34 PM
knight_yyz
Oct 24, 2015 08:05 AM
Pnjboyzz
Sep 21, 2015 12:41 PM
