Alignment Question
Old Nov 12, 2006 | 11:54 PM
zgrm100's Avatar
Alignment Question
So my car was hit while it was parked. Some A**hole probably hit it pulling out of the driveway.
Anyway cosmetic damage aside, my wheel alignment (I think that's what it is) is screwed up. In order for the car to go straight my steering wheel is like 30 degrees clockwise! But also when I turn it all the way counter-clockwise (to the left) and try to make a turn, I hear some loud grinding/screatching/noise. Anu1 have a clue what this could be? Is it that I simply need a wheel alignment and the cause of the screatching is because the wheels are going passed then what they are supposed to go? Any help?
Old Nov 13, 2006 | 01:06 AM
steven88's Avatar
Need A Light?
well the wheel is probably rubbing against something...thats probably why its making that noise
go get an alignment...that should fix it...if it doesn't, the shop will tell you what needs to be replaced...
Old Nov 13, 2006 | 01:08 AM
The Law's Avatar
I R The Law
id say its prob something rubbing
Old Nov 13, 2006 | 01:09 AM
MaxBoost925's Avatar
Drug Money
maybe your bearings are fawk'd? definitely go get an alignment, the shop will give you the 411.
Old Nov 13, 2006 | 02:08 PM
zgrm100's Avatar
thanks guys.
How much should I expect to pay for an alignment? Thanks.
Old Nov 13, 2006 | 02:52 PM
Swiyzee's Avatar
Maxipimp
i think between 60 and 80 dollars for a front wheel alignment. dont quote me on it tho.
Old Nov 13, 2006 | 05:55 PM
steven88's Avatar
Need A Light?
you sir, are correct...
in my area, its more like 40 to 60...i've seen SOME in the 65-70 range....i would never pay $80 for a 2 wheel alignment....overkill if you ask me...besides, shops should know maximas only have toe adjustments in the front...shouldn't be paying more than $50 for toe adjustment...so little work is involved...
Old Nov 13, 2006 | 08:47 PM
NisTech's Avatar
The suspension stoppers usually make that noise when turning all the way at low speeds. Just put some bearing grease. I's a bolt that sits on the hub and when turned all the way it makes contact with the control arm atopper. Normal. Try lubing that first.
And to fix the alignment there is a free way. Go to a parking lot, pull the steering wheel opposite to the side it sits uncentered. Turn it all the way and give it a little tuyg. It will get back top normal haha. But just don't hammer the steering wheel Just a little bit and it should come back.
Alignment is the proper way
Old Nov 13, 2006 | 10:13 PM
notuptodateguy's Avatar
Would this work or mess up the car in any way?
Old Nov 13, 2006 | 11:57 PM
Drug Money
I get my alignment for $40 for 4-wheel alignment from my friend whos a Nissan Technician
too bad they dont do 19" rims though
Old Nov 14, 2006 | 05:33 AM
Trurida18's Avatar
The nissan dealers here charge $79 for a damn alignment. its one helluva rip off. i get mine for about 50 bucks
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
doctorpullit
Mar 29, 2016 11:08 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
