Gas overflow
Old Nov 20, 2006 | 11:04 AM
Whiggy's Avatar
Gas overflow
Every time I fill up the tank the gas flows over and out and then I have to wipe the car, my hands, sometimes my shoes...
What's up with that? Is that normal on these cars?
I don't even click the gun one or two more times after it's full but it still happens.
Old Nov 20, 2006 | 11:07 AM
707SE's Avatar
never happened/s to me. Do you go to the same gas station? Could be their equipment. Beyond that I'm not sure what to tell you.
Old Nov 20, 2006 | 11:10 AM
ICEMAN76's Avatar
I've done it at 1 gas station and then I switched pumps the next time I went there and it didn't happen again. I would try a different gas station and see what happens.
Old Nov 20, 2006 | 11:14 AM
ICEMAN76's Avatar
707 has a point.
Old Nov 20, 2006 | 12:33 PM
Whiggy's Avatar
I've tried it on two different gas stations, both on which I had previously filled my other cars up many times before. I don't have problems on my other cars so I don't think it's the gas station.
Any other suggestions?
Old Nov 20, 2006 | 01:02 PM
SoonerFan's Avatar
Cletus
the sensor to stop the gas is in the nozzle...there is nothing in the car to tell the pump to stop pumping gas
Old Nov 20, 2006 | 03:03 PM
808MAX-SPEC's Avatar
Gas overflowed on the last refill. Told the station manager to check the pump I used. Just for my reference I should have check to inspection sticker. The pumps at most of the stations I go to have up to date inspections. The big mistake I made was that I pulled the pump out and got slpashed with gas. I should have left it in and let it drain.
Old Nov 20, 2006 | 05:45 PM
jdmaxima89's Avatar
On the pedobear bandwagon
I had been going to the same station for a little over a year in the town I go to school at... but the past two times that I got gas there, different pumps, overflowed on me. I started going to another gas station and havn't had a problem. The guy told me to not stick the nozzle so far in the tank, so I've been doing that and it seems to help.
Old Nov 20, 2006 | 06:21 PM
00MaxSE's Avatar
Pointy Elbows
Never happened to me before. Be sure to clean the gas off your paint with something...not good for the finish.
Old Nov 21, 2006 | 05:07 AM
flxsunxchick's Avatar
USF Class of 2009
I've had that same issue at two gas stations that I've went to. If I wait like five or ten seconds after the gas pump stops the first time, it usually gives the gas enough time to settle, (think when you pour a drink really fast - it starts to foam a little bit but it eventually goes down).
What irritates me more is when they don't have any towels! I've started just bringing my own...
If it helps any, both stations were Shell stations and I don't always use the same pump.
Old Nov 21, 2006 | 09:10 AM
00MaxSE's Avatar
Pointy Elbows
Welcome to the org, chick.
Old Nov 21, 2006 | 09:29 AM
4MySwee's Avatar
Baby Wipes in the car FTW!!!!
Old Nov 21, 2006 | 10:25 AM
MacGarnicle's Avatar
balla.. filling up his tank all the way..
Old Nov 21, 2006 | 10:56 AM
P. Samson's Avatar
If this happens all the time you may in fact have a problem. Looking at the FSM there is a one-way fuel valve at the bottom of the filler pipe at the tank that may be sticking, or the recirculation line or the signal line from the filler neck to the tank may be pinched or obstructed. Maybe a problem with any one of those may prevent the "auto shutoff" feature of the pump nozzle from working. These are listed as possible causes of fueling and strong odor issues. You could physically check the hoses/tubes running from the filler neck to the tank for obvious damage at least. Also check all the lines from the tank to the EVAP canister and the canister itself for obvious damage. Unfortunately there are several other things in the vapor recovery system on these cars that could be the problem as well.
Old Nov 21, 2006 | 07:10 PM
USF Class of 2009
Thank you.
She'll look better soon...as soon as I get some money for it!
Miket2006
Mar 1, 2021 03:55 AM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
