camber question
Old Nov 25, 2006 | 09:09 AM
14psisupra's Avatar
camber question
my brother hit something in the road and the camber on the right tire is now off pretty bad, he took it to a shop and they said it was a bent control arm. iv looked and cant see it, i do know he has a bad cv joint, could this be causing it to have the negative camber that it does after the hit? any advice needed
Old Nov 25, 2006 | 09:39 AM
irish44j's Avatar
retired moderator
I bent my front strut, right where the top of the lower bracket it. Check there too.....
the strut is much more likely to bend before the control arm (thin steel vs. cast iron)....
CV joint will not affect camber.
Old Nov 25, 2006 | 10:17 AM
14psisupra's Avatar
the strut doesnt seem to have any damage, i cant find anything, they also said he need a steering knuckle, possibly the bolt on the bottom of that but i cant tell
Old Nov 25, 2006 | 10:27 AM
00SEMAX19's Avatar
It's either the strut or knuckle. Sometimes very hard to see but deffinately there. Easy fix, get camber kit
Old Nov 26, 2006 | 07:29 AM
Show Maxima's Avatar
a camber kit won't "fix" a broken knuckle, all it will do is be a band aid to the real problem.... just replace the knuckle if it is indeed bent, and then get your car re aligned and you should be fine.
Old Nov 27, 2006 | 12:40 AM
XyNoix-HIC's Avatar
i would look at the arm too though since i remember bending mine and not the sturt when i accidently drifted on to a curb =(. I would check local junk yards before you buy it new, since there are a lot of unfortunate people who get their cars messed up but still have good parts on them. Ask the guy you took it to to show you what could be causin the problem so that way you know your not getting ripped off. Also take it to another guy to get a 2nd opinion. The strut really has nothing to do with holding the weight of the car, its mostly the control arms and spring that do most of the work but i would check the strut just in case.
Old Nov 27, 2006 | 12:59 AM
MaxBoost925's Avatar
Drug Money
You can't see bends in your control arm or shock with your naked eye. The only way to tell is by an alignment machine.
If it cannot align, it means a part is damaged. I remember I had a bent passenger side strut and it didn't look bent while it was on the car, but when I took it to get aligned, it was off spec.
Old Nov 27, 2006 | 11:27 AM
Originally Posted by MaxBoost925
You can't see bends in your control arm or shock with your naked eye. The only way to tell is by an alignment machine...
Thats the dayum truth, and if you can see them, then your parts must be totally f'ed up.
Old Nov 27, 2006 | 11:29 AM
XyNoix-HIC's Avatar
the rear end of the maxima is a solid rear axle your not suppose to be able to move anything anyway
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
