light blinking fast
Old Nov 26, 2006 | 06:14 AM
ypl102's Avatar
light blinking fast
My turn signals and flashers are flashing many times faster than normal speed when turned on. It just started happening and I checked the fuse box and looked for bulbs out but there's none. It seems to blinking faster when the engine is on and the speed varies. Anybody knows something?
Old Nov 26, 2006 | 06:30 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Most likely one of your turn signal bulbs has burned out.
Old Nov 26, 2006 | 08:07 AM
Domf3's Avatar
Most likely a bulb. Check the little wire thing inside your bulbs to make sure it's still attached. Sometimes bulbs still work when before they burn out.
Old Nov 26, 2006 | 08:12 AM
Czerkas's Avatar
I had the same problem on my old car ... it would blink fast but the lights would still work , then sometimes it would work fine a week later ... my bulb was just loose.
Old Nov 26, 2006 | 10:23 AM
opanick's Avatar
maybe a bad relay??? just fix it soon so you dont look like those ricers that look like they have strobes for their turn signals lol
Old Nov 26, 2006 | 11:51 AM
P. Samson's Avatar
Check you battery terminal connections for being clean and tight, but it sounds like it may be the alternator (regulator) going south. Put a voltmeter across the battery terminals and check the voltage for being about 12.5 to no more than about 14.8 when you vary the engine RPM.
Old Nov 26, 2006 | 02:33 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
turn signal burned out or..................blinker fluid low
Follow this link in case you need to buy some
http://kalecoauto.com/index.php?main...&products_id=6
Old Nov 26, 2006 | 03:13 PM
FanaticMadMax's Avatar
It's always going to be a bulb is out front or in the rear, that's what making it blinking too fast
Old Nov 26, 2006 | 03:35 PM
Dust N Bones's Avatar
That stuff works awesome. It's hard to find but well worth the effort once you do find it. You should also probably change the blinker fluid filter while your at it.
6spd4dsc
Mar 4, 2016 05:19 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
dcardello
Sep 3, 2015 11:44 PM
