5th Gen LSD Options
5th Gen LSD Options
Ok, so I got to wondering has anyone on the board tried the phantom grip LSD's for the Maxima?
http://www.phantomgrip.com/product_l...p?make=Nissan#
I had one of these installed on one of my 240sx's last year and it worked great, no complaints at all.
Yes, from what I understand the VLSD from the 01 AE will work. But you will need to swap the driverside driveshift.(I believe)
The phantom grip is actually a component that you add to your existing diffierintal to make it LSD.
On the 240sx I had to drop the rear end and take the pumpkin cover off and insert the phantom grip.
hmmm did you try dave burnett? I am purchasing an H-LSD from him for 450 and he told me I don't need to change the axles so I am popping that in. Then motor mount inserts, lots of energy suspension bushings, and stainless steel brake lines.
I have heard of the phantom grip. How does it work? How much does it lock? I meen a LSD on my car would be helpfull in many situations but a LSD that locks too much has no place on a daily driver that you want to enjoy driving everyday.
If it works well though it has many possible advantages
better in snow (the big selling point for me when it comes to using the car as a daily driver)
Better in the corners, and in a straight line(nice added bonus)
The possible downfalls if it locks too much
Makes a terrible turning radius unbearable
puts more stress on the already weak tranny when launching(I am talkin about the auto trannies here)
Anyone who knows more about it fill me in
David B hmmmm... What do you mean H-LSD unit? I thought you had to change out the Tranny or is that just on the 5th gen?
Oh, and this link tells how the Phantom Grip works
http://www.phantomgrip.com/how_it_works.htm
Decoy036SPD, it's a little more involved than just an R & R for the diff. Unless you are experienced with replacing ring and pinion gears AND their set-up I would plan on bring it to an experienced shop. Your knew HLSD diff will have to be shimmed side to side to achieve the same spacing as the origional open diff to keep the same contact patch with the pinion gear as the origional. Otherwise you may end up ruining your ring and pinion or worse.
Originally Posted by Gjohnson
Hey Irish, I know you do autocross, what did you do about LSD? I didn't see anything on your sig or website.
It would be nice to have for the snow/ski trip too, but I have better things to do with the money and I'm more or less done with any major mods to the maxima. New house coming soon....
MAXSE5SPD
Sep 17, 2022 04:00 AM
