01 Maxima with 105k - need a checklist before buying
Old Dec 1, 2006 | 12:12 PM
ferrari4a's Avatar
I am getting ready to grab an 01 max with 95k from a dealership by today or tomorrow. They are letting it go for $9k. Is there a quick checklist I can go through to make sure there is nothing I should be worried about?
I saw some posts regarding coils going bad and it has gotten me worried. I had a 00 max se for a year but it ran flawless the whole time.
(Sorry for a dumb post but I am new to the car. Better safe than sorry)
Old Dec 1, 2006 | 12:32 PM
ferrari4a's Avatar
NM. I just saw all the stickies for the 5th gen. It looks like they cover all the info I need. It looks like I might even be safe from the tranny TSB since mine is later... JN1CA31A21T100476
Lets hope no coil issues!!
Old Dec 1, 2006 | 12:34 PM
Bones45's Avatar
'01 max with 95k for 9k?
They kiss you first?
Old Dec 1, 2006 | 12:40 PM
Ollie's Avatar
Check to see if the MAF (Mass Airflow Sensor) (the black tube after the throttle body and before the air cleaner box)) is the newer 22680-2Y001 - If not - tell him you want that installed and the ECM updated. If it's dirty, you should be able to rub the side of it and it'll show the part number like 22680-AD600. This part cost $120 but the reprogramming is another $100
Also - find out if the ECM part number is on this list - if it is have them perform the ECM reprogram. See NTB - http://www.nissanhelp.com/Ownership/.../NTB00-070.htm
If it's not - you may be replacing a $600 pre-cat and a $100 o2 sensor in the near future.
This is the stuff I'm going through right now at 101Km and have to pay for.
If they agree - have them give you a printed copy of there updates on the ECM. Once those software updates are done - you should be able to repair any ignition/emission thing on your own.
Good luck - fun car!
Old Dec 1, 2006 | 12:45 PM
Bones45's Avatar
Old Dec 1, 2006 | 03:23 PM
gephelps's Avatar
Wear old clothes and take the largest flashlight you can find. Crawling all around and under the car will give you a much better idea than taking someone's word about anything.
Old Dec 1, 2006 | 03:24 PM
AuAltima3.5's Avatar
Check the trans fluid and see if it is dark, and if the trans engages immediately after you shift it into d or r.
Old Dec 1, 2006 | 08:15 PM
joemax1's Avatar
is it 105k or 95k?
Old Dec 1, 2006 | 08:37 PM
OC guy's Avatar
2002 maxima se
i believe its almost time for that car to need coils, plugs, maf airflow sensor, 02 sensors, struts etc etc. i bought mine 2k1 about 2 years ago and it had nearly 70k i ended up replacing everything that i just mentioned and tommorow i am going to have new MAF installed. my car currently has 119k so you can imagine that in 2 years i have nearly spent $2500 on car including brakes, struts, tires, sensors, coils etc etc. so if you paying cash to dealer then thats not a good idea to spend 9k on 01 maxima that already reaching 100k. but if you are getting financed then take a shot but make sure you start saving money for the things i just mentioned. a smart guy would go for toyoya or honda but its your choice and to each his own. goodluck!
Old Dec 1, 2006 | 08:45 PM
OC guy's Avatar
2002 maxima se
by the way i am going monday to get the ecm reprogram do you think i should ask for the ecm update printed copy too?
Old Dec 1, 2006 | 09:24 PM
ferrari4a's Avatar
I know what you mean. I've had nissans for a while so I understand the price can be brought down. Here is the inside story: my wife bought an explorer before she met me and has a very rediculous over priced loan that no one would take. I finally found this place that took a hit on it and ofcourse I am taking a little hit too... (can't live with 'em and can't live without 'em)
Old Dec 1, 2006 | 09:27 PM
ferrari4a's Avatar
Trans fluid looked very beautiful (crystal). The shift is also very very smooth even if I redline and let it autoshift. I was surprised about that. So far so good.
Old Dec 1, 2006 | 09:32 PM
ferrari4a's Avatar
Thanks for all info so quick. Its 95k. I will check the part number on the maf and find out whatsup. The tires/brakes/struts are all new from nissan. They even have receipt for all the work done including each oil change. My old 00 max didn't ride this nice and that was an se suspension.
Old Dec 1, 2006 | 11:20 PM
foodmanry's Avatar
Da Roller Coaster!
Yeah SE suspension is a little stiffer on the springs than the GLE and GXE. Hope you have good luck with that 2k1. It seems like the major stuff everyone talked about is hit and miss. That whole pre-cat issue the biggest one of all....better to just keep checking to see if anyone on the board has a pre-cat for sale and ****** it up just in case. Shelling about $400 to $600 for a new pre-cat is no fun. However the install is pretty easy...just need an impact wrench.
Old Dec 2, 2006 | 06:23 AM
tbombs32's Avatar
my brother just got an 01 for $7200 111k miles...got some codes for the Cat but its just a reprogram issue the nissan dealer did...
Old Dec 2, 2006 | 08:42 AM
foodmanry's Avatar
Da Roller Coaster!
It depends on what codes they throw. The P0430 and P0420 are the ones that usually require replacement of the front pre-cat. Replacing the O2 sensors, and/or reprogramming seems to help a bit, but usually its the pre-cat that ultimately fails.
Old Dec 3, 2006 | 10:30 AM
Ollie's Avatar
This is where I just bought mine. A good deal. Dallas from Warpspeed turned me on to these guys. Not cheap but better than 400-600 bucks.
http://cgi.ebay.com/ebaymotors/ws/eB...m=120047755426
Old Dec 3, 2006 | 10:34 AM
Ollie's Avatar
sure - I would....then you should also get with that your ECM part number.
Do you think I can drive about 2K miles without the MAF reprogram? Gotta long trip coming up for business in the next couple weeks.
Old Dec 3, 2006 | 10:37 AM
RLW001's Avatar
Check list:
1. Sneakers
2. Run!!!
3. Keep Shopping. If you can hold off a month or 2, car dealers get real slow in late Jan-Feb-Mar and are happy just to see a face in the dealership. The end of month as well as the dead of winter are the best times to buy a car.
01' with 95K sounds like a bad deal and problems waiting to happen.
Old Dec 4, 2006 | 06:48 AM
byau's Avatar
Wow, I didn't know that is such a horrible price. I'm new here and can't post my own thread yet but had a quick question about price. I'm considering an 02 SE 6sp, no sunroof, 70k miles. what is a "good" price for it? A good price as in a price that YOU would be willing to pay for one. I currently I'm driving a Scion tC and while it's a great car, I want something with 4 doors and some power. Also, any common problems I should look out for? I don't think the owner has done the regular scheduled tune ups, and a friend of mine mentioned the 60k tune up is quite costly. Please hit me with some knowledge guys!
Old Dec 4, 2006 | 08:01 AM
20max01's Avatar
Check out KBB.com....wholesale, trade and list.
Old Dec 4, 2006 | 10:30 AM
OC guy's Avatar
2002 maxima se
ya i went to dealer to get the reprogramming done. and i asked for the printed copy of ecm reprogramming and the lady said we dont usualy provide that but she will try to get it from a service guy. and do you how long it takes for maf to readjust and for idle to relearn with new maf? because mine still stalls sometime when i start the engine. even though its new updated maf.
Old Dec 4, 2006 | 11:02 AM
Ollie's Avatar
I don't know....I was hoping to ask you I'm puting mine in along with my Y and pre-cat next Saturday...provided my Y makes it on time. I probably won't get a reprogram after a couple thousand miles though......
Old Dec 4, 2006 | 12:44 PM
byau's Avatar
I looked at KBB and just wanted to see what people thought. Sometimes I know for some cars it's tough to follow KBB and NADA prices since a car is only worth as much as someone is willing to pay. So in general the listed KBB prices is what people will consider a good price? So if I can get it for less than KBB then it's good I'm guessing. What are people generally paying for their 02 SE 6sps?
Old Dec 4, 2006 | 01:49 PM
ferrari4a's Avatar
Its always good when you get your car for less than kbb...
I bought my 00 SE 6sp for 6k. Drove it a year then sold it for 6k.
(I paid extra for the 01 because they were going to knock off my wife's junk)
Old Dec 4, 2006 | 01:52 PM
ferrari4a's Avatar
Here is something I don't hear everyday. I called the dealership selling it and they have actually done the maintenance including the replacement of maf and knew when I gave list of the TSB's.
(A dealership that is targeting towards peace of mind for the customers... Nissan customers? I am speechless.)
Old Dec 4, 2006 | 02:20 PM
OC guy's Avatar
2002 maxima se
oh ok I have already figured that it takes few 100 miles of drive for maf to readjust etc. i just got the ecu repro done i dont feel any diffrence performance wise but i bet the gas mileage would be better. overmore the ecu reprogramming is necassary with new maf so dont delay this process. goodluck.
Old Dec 5, 2006 | 07:51 AM
Ollie's Avatar
I just scheduled an apt. for Thursday. Looks like I need to install the MAF in the butt cold weather.......
kjlouis
Nov 24, 2018 06:09 AM
ah2002
Mar 9, 2016 01:42 PM
Wolvee
Aug 11, 2015 12:24 PM
MikesChevelle
Aug 6, 2015 11:36 AM
