How to take front speakers out?
Old Dec 4, 2006 | 10:55 AM
dhl424's Avatar
could someone post the link on how to do this?
thanks
Old Dec 4, 2006 | 11:07 AM
MIXXMAX's Avatar
Can't find a link, but it's real simple to to access the front speakers. In removing the door panel, just follow these steps.
1) Roll power window down.
2) Remove screw cover cap in pull handle cup on door. Remove this screw.
3) Remove step light cover and disconnect harness.
4) Pull and remove driver's power window/power lock switch, Disconnect harness.
5) Remove screw cover cap in mid-upper door on right hand side. Remove screw.
6) Pull door panel off.
7) Done.
Old Dec 4, 2006 | 02:08 PM
xnyc's Avatar
you dont need to remove step light cover. just take the panel off and take the clip off the back of the light with the panel off. save some time.
also where step3 is, you have to take the plastic trim around the lock and handle off. its a little oval trim peice. use a pick and pull it from the front. its hinged towards the back and clipped from the front and sides
Old Dec 4, 2006 | 03:11 PM
stormbringer03's Avatar
if you dont have a bose system be prepared to hunt for speaker brackets
& the scosche dont fit large magnet structure for 6.5/6.75 for ex my diamond d6 did not work with scosche bracket fyi mdf wood works good have fun
Old Dec 4, 2006 | 04:13 PM
MIXXMAX's Avatar
Oooops...good looking out. Forgot about the door handle. Thanks.
wyobbagy
Jan 3, 2023 12:03 PM
9aj9
Apr 5, 2020 12:11 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
