Hissing sound from intake
I have a hissing intake problem. When ever I cruise it's the worst. When I say cruise I mean mantain the same speed. It's so bad that I can't drive with the driver's windows down. It is pretty loud. Does anyone ahve the same problem. It almost sounds like a worn brake sensor. PLEASE HELP!!
Mine does that too between 0-3500rpm. It is normal for the intake...shouldn't be crazy loud though but it can be heard easily. Check your install again and make sure everything is tight...check your filter be sure it is on tight and looks in good shape. Otherwise it is just doing it's job!
Originally posted by cobymoby
Stillen
Stillen
I've done the install three times with two different intakes. I have a stillen and Jim wolf. I thought that it was stillen's over priced intake so I went out and got a Jim wolf, but same darn NOISE! I'm pretty mechanically inclined so I know that I did the install correct. Your problem sounds like mine too. Only at low RPM's.
I have a Place Racing CAI and I have the hising noise too. It is normal because my friend has an Acura Integra with a Intake and he's does it too, I wouldn't worry, just do what "phatguy" said and make sure everything is tight. Good-Luck
litch
123
Jan 4, 2024 07:01 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
