For those who've baked their head lights... enter
Hey,
So last week I was preparing to clear my 02 headlights, black them out etc etc.
I got them removed using housecor's write up along with a couple others I found via search. Followed the instructions regarding baking them @ 200-250 for about 20 minutes, took them out and went to work on seperating the lights.
Now, I know these things are expensive and I didn't want to fug with them. Anyhow either I didn't leave them in the oven long enough or am doing something wrong because I couldn't get those f'ers apart for the life of me.
So first off any suggestions are greatly appreciated but help me by answering the following:
1. How long do I leave them in the oven? By that I mean by looking at the headlights, how can I visually tell they are ready to seperate?
2. Once they are ready to seperate do I pry them apart? I noticed what I guess you can call clips or in other words where the plastic clips/hooks into the housing. I started to pry on that but no luck.
It was frustrating because I was trying to follow Housecor's instructions but it seemed extremely vauge on these points. Anyone else who's done this please offer advice/suggestions. As you know the replacements aren't cheap so you too were probably nervous when it came time to do this.
Thanks in advance
Thanks in advance
yea check the 3 screws. 2 will be around where the headlight meets the fender and 1 on the bottom. also, i started prying from the side closest to the grill. work your way slowly and bake again if you have to. you cant really tell by eye if its ready. you'll feel it though. stick a flathead screwdriver or butterknife in between the lense and the housing and see if its soft, if it is, then your good to go.
Bake it longer, it won't hurt the light housing. You have to feel with the screwdriver to see if it is soft enough. When soft, you don't have much time to pry it open, I'd say max 5 minutes.
Be confident and swift.
check my thread out: http://forums.maxima.org/showthread.php?t=455234
Originally Posted by crispykid717
Did you remove the 3 screws around the headlight?
LOL - I just realized something looking at your pics. I mumified my light when I put it in the oven, wrapping it multiple times in towels. I guess I really didn't want to fug it up. But after seeing your pics I realize that could be part of the problem for me.
Anyhow, I'll give it another try.
I NEED to get the haze off my headlights and then early 2007 im gonna do a front end conversion.
But alas, i would like to know what type of polish i should be using, and which grit sand paper, i dont have alot of haze just some forming around the top of my headlights.
Am i supposed to be using 2000 Grit sandpaper WET, WITH SOAP AND WATER?
thanks for any assistance
Originally Posted by IllegalMax
this has nothing to do with this thread but does anyone know where to get carbonfiber eyelids for a 02?
http://forums.maxima.org/forumdisplay.php?f=21
Hurry! http://forums.maxima.org/showthread....=1#post5411656
but yeah...i had mine in on 250 temp....and for 15 min...and make sure you take those 3 screws out, and just work on it hard, and it'll come apart
good luck
i used a butter knife to take them apart. at first i didnt want to ruin them so i went easy but you have to use some force, it didnt come apart like i expected but yeah pry that sucker apart, youll get it. take your time, the glue will stay soft for awhile, and use some muscle.
why don't you guys buy a heat gun? i think it costs like $20 or so, and you don't have to worry about melting your headlight
the ones with the 2 way temp from 350 or 800 degrees or so
if you have a harbor freight around u, they always have that on sale
knight_yyz
11-01-2015 01:34 PM
worldwiderecognized
09-30-2015 01:16 PM
