hose just for looks?
i have a 5.5 with the berk intake, that little "rod" that comes off the side of the intake and the hose connects to it from the engine block... i feel no suction or anything there, what exactly is this hose for? thanks
Originally Posted by Orgullo
Make sure you connect it to your intake or otherwise you'll throw off your ECU. I learned my lesson. I ended up having to reset my ECU via how to's here.
Originally Posted by mitymax03
i didnt really like the hose on my injen , so i just took it off and put the lil air breather filter . i think it looks alil better then that hose just my 2cents.
I would suggest you put back the hose I think its got sumthing to do with the oil. I was working on my car one day with a friend folded to hose to get more room but forgot to straighten it back. I drove to work as soon as I got off the freeway I noticed the oil light flashing pulled into a gas station shut off the car opened the hood and straighten the hose then pulled the dip stick and it sound like the was air in there.which is due to the restriction in the hose. So disconnecting the hose is not a good idea.
Originally Posted by irish44j
The hose isn't there to "look good," it has a function.
NOT having the STOCK crankcase vent hose attached to the engine intake is in violation of the EPA regulations regarding auto pollution. You can do jail time! Hook it back up. Plus........ using the "filter" is aftermarket LAME and MICKEY MOUSE.
never said it didnt serve a purpose, just tellin him there is a alternative if he didnt want the hose there. Hince thats y i said to put a air breather filter.
newbie, please stop passing bad information as gospel...and being rude while doing it.
learn a little about your car before giving advice
Pulling your leg to some degree........but, practically for our cars, removing the crankcase vent hose from the intake can create performance issues as alluded to by someone prior, because the MAF is not sensing the air WHEN this air is entering the intake (downstream of the TB) via the PCV valve. This air supply is actually originating from the crankcase vent, which is normally supplied by air from the intake "air box". (It will have no affect when the normal "backflow" of crankcase vapors/blowby occurs at or near WOT.)
HerpDerp1919
09-29-2015 02:02 PM
