replacing PCV valves makes any diffrence?
Old Dec 17, 2006 | 12:23 PM
OC guy's Avatar
2002 maxima se
I nearly got 120k on my car and my local mechanic chage $50 to replace pcv valves. is it worth having them replaced or just leave them the way they are, and does replacing them makes any difference in performance or anything? and how many pcv valves are there?
Old Dec 17, 2006 | 12:34 PM
SoonerFan's Avatar
Cletus
there is one valve and you need to change it.
if its clogged you can get to much pressure in the crankshaft which can blow seals.
http://en.wikipedia.org/wiki/PCV_valve
Old Dec 17, 2006 | 12:41 PM
OC guy's Avatar
2002 maxima se
do you have write up for 01 maxima and how hard is that thing to remove and what is (pcv valve grommet) do i need a valve and a grommet?
Old Dec 17, 2006 | 12:44 PM
SoonerFan's Avatar
Cletus
i replaced its on my 00 but dont have write-up.
if i remember correctly, its on the drivers side of the engine near the rear bank. lemme see if i can find something
Old Dec 17, 2006 | 12:48 PM
SoonerFan's Avatar
Cletus
ok...well you asked this question a couple months ago and got the information you needed...pic of location on page 2 http://forums.maxima.org/showthread....ight=pcv+valve
Old Dec 17, 2006 | 01:00 PM
OC guy's Avatar
2002 maxima se
lol how stupid of me. i didnt know the question was prevously posted. thanks for refreshing it for me. but now the question is (what is PCV Valve Grommet) do i need that along with pcv valve?
Old Dec 17, 2006 | 01:04 PM
SoonerFan's Avatar
Cletus
i cant remember...i know it wasnt a seperate piece. its either part of the new valve...or still on the car after you remove the old valve
Old Dec 17, 2006 | 01:09 PM
OC guy's Avatar
2002 maxima se
thanks alot. so where did you buy yours? i believe autozone got them but i doubt that they are the OEM ones. should i just go with any brand or its better to buy the standard oem replacement?
Old Dec 17, 2006 | 01:11 PM
SoonerFan's Avatar
Cletus
thats also answered in the link posted in your original thread
i just bought mine from autozone...OEM isnt any better.
Old Dec 17, 2006 | 01:16 PM
OC guy's Avatar
2002 maxima se
lol thanks and ciao.
gotta run to autozone!
Old Dec 17, 2006 | 02:19 PM
JaKillz2's Avatar
http://forums.maxima.org/showthread....&highlight=PCV theres pics as well on the second page for both the 5th and 5.5 gen.
Old Dec 17, 2006 | 02:45 PM
aw89maxSE's Avatar
I just did mine a few weeks ago and I think I noticed a bit more of a smoother idle. I also got an oil change done so all together, I noticed a bit of an performance booster.....or maybe just back to the way the car is suppose to run lol
Old Dec 17, 2006 | 03:22 PM
SoonerFan's Avatar
Cletus
already posted...
Old Dec 17, 2006 | 03:38 PM
OC guy's Avatar
2002 maxima se
problem solved work done thanks to all of you for your informative feedbacks. this just saved me $50 and now its time to donate $20 to ORG.
Old Dec 17, 2006 | 09:40 PM
MaxBlu5's Avatar
You think you can let us know if you notice any improvements? I have 83k on my car and thought about changing out my PCV also.
Old Dec 17, 2006 | 11:27 PM
OC guy's Avatar
2002 maxima se
so far it feels the same no big difference but i believe the main reason to replace the pcv valve is clogging of the air flow into crankcase etc. mine wasnt clogged but i still replaced it to be on the safe side. bought one from autozone paid $4.50 and it works same as OEM. i got 01 max so it was not hard to remove the old one and install the new one back on. heres a trick when you remove the old one just pull the hose where the valve is connected without removing the clamp and the pcv valve will pop right out then just put the new one back on hose clamp it and stick it back in the hole with some pressure. and make sure to remove the other side of the hose too so you can have good grip. this can be done without using the pliar. using the pliar can damage or drop the valve. goodluck.
lowpost99
22
Sep 2, 2015 04:38 PM
lux97Max
19
Aug 27, 2015 07:48 PM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
