Control arm question
Old Dec 17, 2006 | 02:12 PM
Matt_01SE_20th's Avatar
I just removed the control arm on my 2001, and need to transfer the "bush link pin" from the old one to the new one. Is this a press fit or is it just stuck? It did not appear to be an interference fit, and the FSM makes no mention of needing a press but i cant seem to get the link pin out. Is there any trick to this?
Old Dec 17, 2006 | 03:24 PM
NisTech's Avatar
bush link pin? you mean cotterpin? try to pry it off with side cutters and if you damage it too much punch it with a punch through the whole...
You don't need a press That's the ball joint one.
To get the balljoint out you hamer the actual round housing that the balljoint pin sits in couple of times.
Old Dec 17, 2006 | 03:49 PM
irish44j's Avatar
retired moderator
no, he doesn't mean cotter pin
the bush link pin just give it a good whack with a mallet and it will pop out. I've done it a couple of times. It kind of gets seized up tothe inner collar of the bushing sometimes.
Old Dec 17, 2006 | 03:51 PM
no. Not the cotter pin. On the control arm there are two units that connect to the chassis. One is a circular bushing with a 2 bolt housing. The other is a "link pin" which is a 4 bolt piece that fits into the LCA and is then secured to the control arm with a nut. this is the part i need to know about the fit on.
Old Dec 17, 2006 | 04:15 PM
Irish,
I tried wacking it out with a rubber mallet and a standard hammer (not a good idea, so i stopped). I have it soaking in some kroil right now to loosen it up a bit. Is there any other trick to it? Is there another way to break the inner collar loose?
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
