01 Maxima.. How to remove windsheilf washer nozzles??
Old Dec 19, 2006 | 03:20 PM
makaveli3004's Avatar
Anyone have detaled instructions or a how to remove the wind sheild washer nozzles. Also anyone know where to buy new guages for like just the guage faces not the whole cluster on a 01 se maxima?
Old Dec 19, 2006 | 04:39 PM
MIXXMAX's Avatar
Removing the nozzles should be the same procedure when I had my '95. Try the following:
1) Open hood
2) Remove protective cover underneath hood.
3) Disconnect hoses going to each nozzle. (They should just slide off).
4) Squeeze and push upwards on bottom of nozzle. (They are just snapped in hood).
As far as the guages, any Nissan dealer sells each individual guage in the cluster for the 2k and early 2k1 models. But, you're probably better just buying the whole cluster off Ebay for cheap. I have a '01 cluster for sale, but it's the later one with the whole guages as one piece, though. Let me know if you're interested.
Old Dec 19, 2006 | 05:18 PM
Yes mine is all in one piece for the guages i guess i have a late model 01??.. anyway with the nozzles the tube seems to be on there quiet good i pull it an it doesnt budge feels like its gonna rip apart. and the whole is very small to get to you can barely get your fingers in there.
Old Dec 19, 2006 | 06:55 PM
foodmanry's Avatar
Da Roller Coaster!
Needlenose pliers are your friend.....
Old Dec 20, 2006 | 08:16 AM
MacGarnicle's Avatar
No need to remove cover under the hood. There are 2 holes forward of the cover where you access the nozzles. Use some pliers to squeeze the clips together and just work it out. The tube is easy, just twist and pull at the same time. It will come off, just work at it.
Old Dec 20, 2006 | 12:33 PM
BigFly_2K2SE's Avatar
When I changed my nozzles I had to pull that tube like a **** to get it off. I actually thought I was going to wreck it but it finally popped off.....no harm done.
Old Dec 20, 2006 | 01:34 PM
It was kind of tight for me as well. I'm guessing the tube slowly forms to the ribs on the nozzle that are keeping it on. It's a matter of pulling the tube past those ribs so it can just slide off. In any event, the tube seems fairly sturdy and not easily broken by pulling.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
