Check engine light wont go out
Ok well i disconnectd the brake booster hose so i could spray carb cleaner in it to clean the manifold and after that took out the air box so i could clean the throttle body w carb cleaner. THe check engine light is on and wont go off. I know the engine was reading that the mass air flow sensor "was broke" as no air was flowing past. NOw the check engine light is on and wont go off. And yes i did the ecu reset procedure wit hthe gas pedal and such but no results. Any hints other that going to my fathers and connecting to a scan tool to clear the light?
well got the code cleared last night. Hooked up the scanner and at first it was a 1102 code " mass air flow sensor" like i thought. Cleared it and it came on again. WTF. I just took care of it. So hook up again and now a 0507 code. Code for the throttle body. Checked a bunch of stuff and then shut car off, disc the plug to the tb and cleaned it and plugged back in.... cleared code, drove it and now its bye bye light. Moral. Check connections cause that may throw a code and urk you all day for no reason but to just clean the connections.
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
